20 Most Recent Quasar VV2007 20 in. Combo Questions & Answers
When ever I press the channel button it goes up
You didn't say the brand or model so its kind of hard to help...try doing a factory reset, again if I knew more I could tell you how to do it if your not sure
12/4/2017 10:03:56 PM • Quasar VV2007 20... • Answered on Dec 04, 2017
I need the codes for
here the Codes for the Quasar TV VCR VCRC Quasar 0035, 0162
9/26/2012 6:47:19 PM • Quasar VV2007 20... • Answered on Sep 26, 2012
2answers
Cannot turn tv on or off remotely. Tv works fine
Take the remote control aparts,take some Q tips dips it in with some rubbing alchahol.Clean the remote control PCB board,putting it back together again,wait like 20 mins.Put in new batteries.The remote now should work again.If not it garbage,because it CPU chip is dead.Try website like Remotes.com to buy an exact remote to ur original remote.
11/18/2010 1:06:11 AM • Quasar VV2007 20... • Answered on Nov 18, 2010
I have a Quasar tv/vcr
Sometimes the universal remotes do not compromise fully with certain models especially with combo models.
So you might a different type of universal type to connect with the Quasar codes, but it is ideal if there is the model mentioned in the manual of the remote.
Volume and channel working is what is most important and should be considered good enough.
9/14/2010 6:15:29 AM • Quasar VV2007 20... • Answered on Sep 14, 2010
My universal remote will not work on my VV2006. I
Get codes from
www.remotecodelist.com
www.tvcodes.com
www.remote-codes.com
try new code. Try different remote. then go to tv menu, find "autoprogram" feature and select it. It will scan all available channels
8/27/2009 1:42:47 PM • Quasar VV2007 20... • Answered on Aug 27, 2009
Correct input tv
ok what cable uusing form cable blx hd hdmi cable or cox cable or yellow ?
10/7/2008 5:04:40 PM • Quasar VV2007 20... • Answered on Oct 07, 2008
Good picture good sound use antenna
This is a simple problem, somehow ypu have the closed caption on, either from the remote hit the CC or closed caption button till it says off or find the closed caption in the menu and turn it off
3/10/2008 10:32:31 PM • Quasar VV2007 20... • Answered on Mar 10, 2008
0answers
What remote will work with Quasar SQ4001
the one stated in the free sq4001 manual or a relic universal remote , rare i bet.
7/25/2022 11:57:33 PM • Quasar Televison... • Answered on Jul 25, 2022
2answers
1977 CRT TV wont turn on
Not sure why anyone would want to repair a non hd TV as the picture quality isn't usable with modern content but if you're doing it because you like restoring something vintage here are some ideas. Some CRT sets use a pulse from the back side of the flyback transformer as a starter voltage supply, it needs this short pulse to start the power supply, it's kind of like starting a gas motor, the starter only runs for a short time then the gas motor takes over, this signal needs to be measured with a scope or a high end meter, this was a common issue with a lot of older CRT sets that use this type of power supply. I'd look at the start up supply as without that the regular supply isn't operatable.
7/25/2022 9:19:03 PM • Quasar Televison... • Answered on Jul 25, 2022
How do u switch the settings on a Quasar TV/combo to the av Jack's from the cable jack it's a older TV that I use sometimes
no model TV told at all.nor year made. 1967 to 2004?????? not sure what you are attempting at all first off there are no more VHF/UHF wide band TV now. its all gone. bye bye. HDTV yes , old analog is gone. buried. this TV is NOT CABLE ready, back in 1967 era,no such thing. make relic TV work needs a video to vhf channel 3/4 converter like old Pong or ATARI games had. yes there are converters. to do video to modulated channel 3/4 but not told at all what is your video choices,?sources. DVD RCA video jacks. cable modems do not have those. I bet you have cable modem or a SAT modem and converting HDTV to analog is wow hard. if not impossible one can record a video sources and convert it using PONG adapter. to old CRT motorola quasar. quasar Company ceased to exist in 2004. ! Beside Uwave ovens. and Motorola 1974 sold its television business to Matsushita Electric, now Panasonic https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313&_nkw=+RF+Modulator+RCA+Input+Channel+3+4+Adapter+Output+&_sacat=0 the above will work ch.3/4 VHF with video sources.
7/24/2022 2:15:46 PM • Quasar Televison... • Answered on Jul 24, 2022
I have a Quasar 50in model number sq5000
Your EEPROM is bad, if you can find one and have soldering skills and the equipment to remove and replace SMD devices that's the cheap way to fix( $15) if not replace the main board, in your case with the sound issue it may make more sense to replace the main as that should correct that isue as well
1/23/2022 2:13:33 AM • Quasar Televison... • Answered on Jan 23, 2022
Quasar model # RC2030Q
Your issue is .................................
2/3/2021 2:32:41 PM • Quasar Televison... • Answered on Feb 03, 2021
I want to get an antenna for my Quasar VV-2000. What is best for this model and will I need a converter box?
you will need both a digital antenna and a converter box. if you can put the antenna on the roof or on a tower. if you had a newer tv all you would have to get is just the antenna
9/6/2018 1:18:33 PM • Quasar Televison... • Answered on Sep 06, 2018
Quasar television radio combo. ANY way to get channels without a buying a converter. It has screw connections that looks like you are to use some type of uhf transformer type thing. I do not have any of those. I have a vcr and some wire. ANY help???
I haven't heard of a radio/tv combo since the demise of vhf tv. A reasonable radio reception could be derived from the vhf tv signal making a usable unit without the bother of an additional aerial. For use with uhf tv the radio would probably need an additional aerial for decent fm radio reception - unless the radio is am only... You don't say how old your combo is or give any details. I think the screw terminals could be intended to be connected to a 300 ohm balanced dipole aerial for radio reception only or to mount a loop aerial for indoor tv reception only, if the tv is intended for uhf analogue reception. If the tv isn't equipped with a standard socket for the usual 75 ohm coaxial type aerial lead it is possible the set manufacturer originally supplied an adaptor to fit to those two screws in order to provide a regular aerial socket. Without a much more detailed description, these are the only comments I am able to make.
4/2/2018 11:57:10 PM • Quasar Televison... • Answered on Apr 02, 2018
Televison & Video Logo
11 questions posted
Top Quasar Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Quasar Televison & Video
Most Popular Question
cannot turn tv or off remotely tv works
  • Televison & Video
