20 Most Recent Quasar VV-2002 20 in. TV/VCR Combo Questions & Answers
VHS tape keeps popping out of VCR.
I suggest you pull it apart and check the many drive belts, they may be defective and loose. If they are replace them all of them.
3/28/2017 6:50:30 PM • Quasar VV-2002... • Answered on Mar 28, 2017
How do I get free local TV over-the-air stations?
The Quasar VV-2002 only has an NTSC (analog tuner). Very few stations with NTSC transmitters are still broadcasting. Only low-power stations were allowed to continue broadcasting an analog signal. Unless you are very close to one of the transmitters, your TV will not tune in the station. You'll need to connect the TV to a digital-to-analog over the air converter box. (The low-end ones that were free or cheap with the government coupon are harder to find; a few models are still available.) These convert the ATSC (digital) signal to NTSC. Then use an appropriate antenna and follow the instructions to tune in the available OTA signals. Send these to the TV either on the RF or composite Line-in. Set the TV to the appropriate input and use the converter box to change channels. I hope this helps. Cindy Wells (20" TVs weren't required to have an ATSC tuner until 2007. Since there are reviews for the VV-2002 from 2004, it obviously is an older set.)
11/19/2015 6:42:40 AM • Quasar VV-2002... • Answered on Nov 19, 2015
What is the tech support phone number. answer below is wrong for me
I bought a Quasar TV 50 cuanta energ?a economisa
11/28/2014 7:41:27 PM • Quasar VV-2002... • Answered on Nov 28, 2014
2answers
Set up for cable
You might be able to restore the factory settings by pressing "play" and "FF" simultaneously and hoding them down until the set shuts off (about 5 seconds). Then when you turn it back on it will lead you through the setup routine, which includes auto channel select.
Plan B would be to buy a universal remote.
5/13/2013 7:10:52 AM • Quasar VV-2002... • Answered on May 13, 2013
I HAVE A QUASAR VV2008
The remote model number for the Quasar VV2008 is VSQS1570 and can be ordered from Panasonic at 1-800-221-7262 or Go to a Family Dollar store and purchase the grey RCA universal remote for $6.00 about 6 inches in length. When you are ready to program it for the Quasar VV2008 push the code search button then the VCR button and enter 0162 then push enter. The red light should go off and the remote should turn the TV/VCR off and on. It worked for me 4/19/2013
4/19/2013 10:29:20 AM • Quasar VV-2002... • Answered on Apr 19, 2013
How to adjust the puicture
most of these the adjustments for picture are only available by using the original remote and entering the on screen menu.
11/7/2012 4:49:03 PM • Quasar VV-2002... • Answered on Nov 07, 2012
3answers
VCR Tape will not play, it keeps ejecting
I have a similar problem. It takes 3 or 4 times to get my Sony VCR to accept a tape. Once it does, everything is fine, until I turn it off. Next day, same trouble. I tried several tapes and brand new tapes. No difference. I have opened the cabinet and used alcohol to clean various stuff, no change.
11/5/2011 10:08:37 AM • Quasar VV-2002... • Answered on Nov 05, 2011
Need a remot for tv/vcr tv
  • Hi, i can help.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
9/24/2011 5:42:50 AM • Quasar VV-2002... • Answered on Sep 24, 2011
Need a remote control
Try website like Remotes.com to buy the tv original remote or very closed compatible one.
9/20/2011 7:11:07 AM • Quasar VV-2002... • Answered on Sep 20, 2011
1994 qusar crystal vision series
Usually, unless a TV was manufacturered proir to remote feature functionalitoes were made. It is expected to be powered by remote controllers acquirable on the market either as the original or likely universal remote controllers capable of acquiring the same functions. If the Tv was incomparticble to remote controlling, acquiring a remote device does not acquire signal transmitioon or broadcasting. Refer to the TV user guide if is available or observe the written areas on reverse of TV to ascertaing the brands, logos that may be indication the TV is compartible to several feature functionalities.
1/17/2011 5:16:23 AM • Quasar VV-2002... • Answered on Jan 17, 2011
How do you stop flashing green light on timer
Set the clock...
7/19/2010 1:08:31 AM • Quasar VV-2002... • Answered on Jul 19, 2010
The TV died-VHS tape stuck inside and I can't get it out.
check the tip in my profile
7/17/2010 9:13:42 PM • Quasar VV-2002... • Answered on Jul 17, 2010
We had power outage when power came back on power
When you have power outtages you always want to have these eletronics in a surge supressor or simply unplugged.
I suspect your having a power supply issue, The power supply is inside the TV, I would not say its a fuse because you do have that blinking light.
1. try to unplug it and plug it back in
if that did nto work your going to need a tv repair shop. You do not want to open this unit if you do nto know how to repair it.
Thanks for your free question, Thanks for using fixya.com please be kind and leave a postive rating or feedback. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
6/30/2010 5:00:36 AM • Quasar VV-2002... • Answered on Jun 30, 2010
Quasar VV-2002 20 in. TV/VCR Combo Logo
93 questions posted
Top Quasar Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Quasar Televison & Video
Most Popular Question
video tape stuck in vcr way me
  • Televison & Video
