20 Most Recent
Samsung PN58C8000 TV Questions & Answers
Need to rerplace Samsung pn58c8000 mainboard
It is not an easy work as you assumes. In most cases, after replacement to this board, a firmware update might be necessary. If you're sound in electronics, check the site linked here for more details.
Pull up previous posts by its left sidebar, or type in the
brand name and model number to of your set, to its search box, and press '
Enter'
or view it in
Mosaic / Timeslide option.
9/5/2013 6:42:38 AM •
Samsung...
Answered
on Sep 05, 2013
Is it worth fixing a
No, a cracked screen, whatever the type, size or model of tv is terminal, unfixable. In a case of a plasma it's even worse - the crack allows the gases to escape which causes the voltages on the panel to spike, frying the Sustain boards.
The tv's are dead, good for parts at the best - a new panel would cost as much as a new tv, plus the shipping.
7/8/2011 9:45:43 PM •
Samsung...
Answered
on Jul 08, 2011
I have a pn58c8000 and
make v reset press the exit button on remote for more than 10 sec message reset will appear select yes tv will turn of turn tv back on and select home use this could repaire your problem
3/28/2011 4:25:35 PM •
Samsung...
Answered
on Mar 28, 2011
Samsung plasma TV PN63A650 will not turn on, just makes continuous clicking.
the capacitors seem to have gone bad if they have like a black dot on them it is a sign they have actually blown they can be replaced by placing new ones on but it would be better if the board was replaced (unless you wish to replace those capacitors please please do be careful in doing so they hold enough charge to give you a bad zap even kill if one isnt careful)
Samsung 60 inch plasma not turning on. Unplug HDMI and turns on. Let it warm up (15min) then one HDI (720) works. Replaced caps but no change.
Fault at its main digital board.
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. ..
Samsung Plasma..clicking pn50a400c2dxza
Have you checked the sustain board/s. If you wish to get some details about how to check a plasma TV, visit the site linked here. It has details with illustrations. The shown is for an LG brand plasma, but all the plasma TVs will have same configuration and checking procedure, irrespective of its brand and screen size.
Pull up older posts. Surf the site with patience.
