20 Most Recent
LG 26LD350 26 in. TV Questions & Answers
Lg blue light flashes
Replace the power supply or at the very least check for swollen capacitors on the power supply
Have lg tv model 26ld350
Yes,the power supply board have a fuse near the edge of the board.That the board,where the power a/c cord plug into it.
Our LG LD350 has an
I can think of 4 solutions....but what has worked for me is unplug it for 10 minutes then power on but dont push anything ....wait a minute for the computer to re-anylize..then go through your set up menu...hope this helps...Replies are appreciated
I have LG 26LCD TV.
sounds like a faulty lcd panel but you will be suprised how many we used to get back where it was something simple like the wires not being connected to the power supply for the screen. the lcd panel is very expensive to replace, nearly as much as the tv itself.
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
