20 Most Recent
Proscan 32LB45Q 32 in. TV Questions & Answers
Proscan tv. blue indicator light is on no pic and no sound. can not turn tv off.
Fault at its main digital board.
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory ResetF (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Tv wont turn on
Check power outlet for power on, whether LED on TV is one after power on. Check whether the LED is blinking. This means there is defect in circuit and this might need attention of a qualified service technician.
Can't get the base off of my Proscan 32LB45Q
- Place the TV faced down on a soft cloth or cushion to protect the LCD panel from damage.
- As indicated in the photo with the arrow labeled "1," remove the two screws at the bottom.
- As indicated in the photo in the box labeled "2," remove the two screws at the top.
- Remove the stand body
Hi the tv keeps turning off what should i do i had
Tries warranty service any how,they might fix it for u.Fix it ur self?Take the tv aparts.Tv have power supply board problems.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new reburbish power supply board for the replacement.
Tv wont turn on after a storm happened in my
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
My tv is blinking a blue light when I try to turn it on along with a popping sound.
It sounds like there may be an issue with the power supply or internal components of your Proscan PLDED5030A-RK TV. The blinking blue light and popping sound could indicate a malfunction that is preventing the TV from turning on properly.
Here are a few steps you can try to troubleshoot the issue:
1. Unplug the TV from the power outlet and leave it unplugged for at least 10-15 minutes. This can help reset the internal components of the TV.
2. Check the power cord and connections to ensure they are secure and not damaged. If there are any visible signs of damage, such as frayed wires, replace the power cord.
3. Try plugging the TV into a different power outlet to see if the issue persists. This can help determine if the problem is with the power source.
4. If the issue continues, it may be necessary to contact a professional technician or the manufacturer for further assistance. They can diagnose the problem and recommend the appropriate repairs.
It's important to exercise caution when dealing with electronic devices, especially when there are signs of malfunction such as unusual sounds or lights. If you are unsure or uncomfortable with troubleshooting the issue yourself, it's best to seek help from a qualified professional.
3/22/2024 11:46:39 AM •
Proscan...
Answered
on Mar 22, 2024
