20 Most Recent
Panasonic TCP50C2 50 in. TV Questions & Answers
Panasonic tc-p50c2 keep blink 10 time what should i do
10 blinks won't occur to Panasonic Plasmas. Visit the site named '
Electro-help' for more
details. Click this
link. View it in
Timeslide" or
"Flipcard" option, which can be selected
from the drop down box menu by the [
Sidebar] tag, at the top left corner
of the display window. You can also
click the [
Home] tab to see the latest updates. It will make search
easy. There are more than 1350 posts to different brand TVs now. Pull up older
posts there.
2/28/2020 11:29:00 PM •
Panasonic...
Answered
on Feb 28, 2020
Tv won't come on, the small green light to
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "
brand name" to your device,
[Exclude the model number] in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts.
9/10/2017 9:43:52 AM •
Panasonic...
Answered
on Sep 10, 2017
Can not access apps
Try unplugging tv for a couple minutes and then plug it back in and see if this resets. Hope this helps.
1/31/2016 8:16:42 AM •
Panasonic...
Answered
on Jan 31, 2016
How do I fix blanking lights with out repeair
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
11/29/2014 11:43:47 AM •
Panasonic...
Answered
on Nov 29, 2014
Panasonic TCP50C2 50 in. TV it is blinking 7 times and wont turn on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes (Error Codes). Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "
Mosaic" or "
Magazine" will make surf easy.
8/7/2014 11:58:21 AM •
Panasonic...
Answered
on Aug 07, 2014
Tv wont power on but the power button flashes a red on light over andover
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "
Mosaic" will make surf easy.
4/13/2014 4:53:55 AM •
Panasonic...
Answered
on Apr 13, 2014
Looking for pairing code
Pairing codes are for connecting bluetooth devices. There are no TV's with bluetooth as far as I know so the answer to your question is no.
1/15/2014 3:35:33 PM •
Panasonic...
Answered
on Jan 15, 2014
