20 Most Recent LG 50PJ350 50 in HD-Ready TV Questions & Answers
Tv won't turn on- its in standby mode. the young lad had the remote before it was turned on.... could he have pressed somethin on the remote which is now preventing it from coming on?
Powering up do you hear the relay click then you may see the display flash (not necessarily), but then the TV clicks back into standby mode. If so there is a component failure. will need diagnosis by a repair shop. Too many different components it could be for me to guess. but the common repair kit containes1 fuse (F302), 1 diode (D304), the power resistors (R927 and R929 for the board revisions with these two resistors) and the IC301 voltage regulator IC.
2/21/2018 3:20:46 AM • LG 50PJ350 50 in... • Answered on Feb 21, 2018
0answers
LG PLASMA TV CLICK SOUND
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
6/21/2016 9:06:30 PM • LG 50PJ350 50 in... • Answered on Jun 21, 2016
Lg plasma tv turns on then off after 5 minutes
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
4/14/2016 8:04:54 PM • LG 50PJ350 50 in... • Answered on Apr 14, 2016
Why does it turn on then immediately turn off?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
1/25/2016 7:43:24 AM • LG 50PJ350 50 in... • Answered on Jan 25, 2016
Traduzir em portugues
Merci ++++
6/28/2015 5:08:04 PM • LG 50PJ350 50 in... • Answered on Jun 28, 2015
Why does the screen not turn on when I turn the power on? How do I fix it?
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis.
6/27/2014 6:55:17 PM • LG 50PJ350 50 in... • Answered on Jun 27, 2014
Turns on and off immediately
Sounds like a bad power supply
4/7/2014 11:36:15 PM • LG 50PJ350 50 in... • Answered on Apr 07, 2014
0answers
Invalid format screen
Check the input source to make sure it is set to HDMI.
1/7/2014 11:36:59 PM • LG 50PJ350 50 in... • Answered on Jan 07, 2014
V3.08.0
hi you will need service remote to get rid of this message hope it helps regards shaun
1/7/2014 7:17:29 AM • LG 50PJ350 50 in... • Answered on Jan 07, 2014
Tv clicks when turned on and screen never comes
Most likely a power supply issue due to failed electrolytic capacitors.
10/25/2013 3:40:04 PM • LG 50PJ350 50 in... • Answered on Oct 25, 2013
Replace screen broken l32w461
It will be better to buy a new one, instead of trying to replace the screen. If you wish to replace the screen, it will cost around 2/3rd of the total cost of a new TV, excluding service charges. Means, you have to spend at least 80% of the new TVs' cost. If you're willing, contact the authorized service center for LG.
10/15/2013 1:54:36 PM • LG 50PJ350 50 in... • Answered on Oct 15, 2013
2answers
Tv wont stay on
I see so many here with no sound/nopicture issues:ISSUES: 1. IF sound main fuse/s are good.2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.4. Be safe and if you do not know what you are doing don't open the set.Answers to issues:1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.6_11_2012_10_22_27_pm.jpg6_11_2012_10_22_47_pm.jpg
3/22/2013 2:00:20 PM • LG 50PJ350 50 in... • Answered on Mar 22, 2013
I have a LG 50" which goes to horizontal half screen? Any ideas?
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Some times, the ads attached with each posts might help you to find the availability of spare parts. There are more than 580 posts to different brand TVs.
8/14/2012 11:52:45 AM • LG 50PJ350 50 in... • Answered on Aug 14, 2012
LG 50PJ350 50 in HD-Ready TV Logo
48 questions posted
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
View Most Popular
  • LG Televison & Video
Most Popular Question
tv tries start but shuts down in
  • Televison & Video
