20 Most Recent
LG 19LH2000 19 in. TV Questions & Answers
No picture on mu LG television.
Try the old flashlight test, turn off the lights in the room. Turn on the set and flash a bright flashlight on the screen. Do you see the image or is the screen totally black?? If you see the image, then most likely you have a backlight problem. Verify that you have 24V on the power supply for the inverter
Blinking LED error code
Tthe blinking light is a code to give you an idea of what the prolem is. The code is descrived in the service manual for this tv. You would have to do a search on the internet for the service manual there should be a few people selling it. This TV is very simply so it's either going to be your power supply or your signal board. You can get parts for this TV at
www.interliquidparts.com
I have a lg tv
You need to replace the mainboard unless lg has a new software update on the web at LGelectronics.com Just search your model number and follow their instructions or if not try places such as shopjimmy.com for your proper part. Hope this will help.....
Sam Farrell
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
