20 Most Recent
Sangean ATS 606 AM/FM/SW Radio Questions & Answers
Sangean ATS 606 A Portable Radio
Remove the battery compartment door and the batteries. There should be a small hole marked "reset" under the upper battery cradle. Press (gently...until it clicks) and hold for 5 seconds. Replace batteries and try again.
Sangean radio
DT-210
Hi Fernando, you put the brand and model of your radio, but do not indicate what problems you have
Comment what you need, so I can give you some idea
I wait your answer
Greetings Franco Dosil
Hola Fernando, pones la marca y el modelo de tu radio, pero no indicas que problemas tiene
Comenta que necesitas, asi podre darte alguna idea
Espero tu respuesta
Saludos Franco Dosil
SANGEAN PRD5 AM TUNING IS OFF.
If you mean that gives odd number, I guess the tuning step is set on 9 kHz, try to press the band button longer than 2.5 seconds during the radio off, it can set the AM tuning step.
