20 Most Recent
Kyocera Mita KM-5035 Printer Questions & Answers
Kyocera KM-2050 Problem error C6400
Fuser unit Error code, you can try to reset, but if the code still there, you need to change the fuser unit.This is the way to reset your fuser code;On the panel press 1087 1087this will take you to the service mode,(look into the screen)now on the panel again press 163 and hit the start key.Look in the screen, you will see execute, select execute by the arrow and hit the start key, the machine will turn off then on. or it will ask you to turn the main power off than on. this might fix your problem, if not! change the fuser. I’m happy to help further over the phone at
https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Replacing a DC controller board
When replacing DC/main PWB or engine board, be sure to remove the EEPROM from DC, main PWB or engine board that has been removed and then re-attach it to the new DC/main PWB or Engine PWB, cheers
Error 2810 on kyocera ta550ci
waste toner motor error, under cover on right side of machine, will have to be replaced. also motor could of damaged PWB.
Kyocera Mita 5035
Go through the maintenance procedures in your manual. All cleaning should be done which probably includes roller cleaning but you should run it through all the procedures.
How do I install a KM-2050 wireless connection on my computer
1. need to get the IP address of the printer, print a configuration page from the printer and that should have it on it
2. open up the add a printer wizard and for the port you need to create a new tcp/ip port with the ip address of the printer
3. you need to have the drivers available on your computer to complete the addition of the printer
let me know if you need clarification on any of these steps
