20 Most Recent
AsianIdeas.com Ninja Uniform with Mask Questions & Answers
Ninja costume with mask
How to Make a Homemade Ninja Outfit
Most people will tell you to just use an old shirt or buy a cheap ninja outfit online. Well this article will tell you a different way. This is fairly authentic.
EditSteps
Pick a color. Ninjas did not usually wear black (however, they did occasionally, so it you want to be a black ninja, it's ok). During the night, they wore colors like navy blue, brown, grey, and, sometimes black. Dark blue is good for moon-lit nights. Black is ok on cloudy nights, or nights when there is no moon (the moonless phase of the moon). During the day, greens, browns and greys are good. When it's snowy, white and light greys are good. (Don't wear white during the night, even if it is snowing. You will stand out.)
Look for clothing of your chosen color in your closet and the closets of your family and friends. Go to your local general clothing store for the pieces you can't find. Try find the athletic clothing section for most of your pieces. Ninja were VERY active.
Try to get a pair of loose, but not too baggy pants. Sweat pants are good. So are some yoga pants. Get pants that are not too thick/thin and are of comfortable size.
Get a long-sleeve shirt. Read the tag, so make sure that the fabric type will be the right temperature. Think about weather it will be, night or day, and how active you will be.
5
If you want your outfit to be a complete dark suit, you might want dark shoes. If you don't have a pair already, find a pair that is fairly lightweight and doesn't make a lot of sound when your walking. Try to get running style shoes, or if your really into it get a pair of barefoot running shoes. Or try being a barefoot ninja (beware of modern ground danger, like broken glass.)
6
Try it all on. The whole thing should look pretty nice. You can find a video on how to make a ninja mask with a shirt on YouTube.
7
When you are dressing, try taking yarn, ribbon, strips of cloth, or thin rope of your color, and tie some around you knees and ankles. This lets your pants louse-er without catching on things.
8
When it is your time to be a ninja, go swiftly and silently. Do not be afraid. Good luck and stay invisible.
9
Finished.
EditTips
Train. Even if this outfit is just a costume, a few good ninja moves are very valuable.
10 Helpful? 2
- Try to make pretend weapons to add some pizzazz to your costume but don't go overboard. Remember ninjas dress light; you can't be stealthy with a heavy bag of clunky weapons.
10 Helpful? 2
Add
What do you pack in your purse?
Here are list of things you can carry in your purse:
A makeup bag. I do my makeup on the go a lot, so a makeup bag is necessary for me.
A pair of earrings / jewelry.
Hair ties and bobby pins.
A hair brush.
A notebook / sketchbook.
A pen and a pencil.
Pack of tissues.
4/17/2024 7:09:47 AM •
Clothing...
Answered
3 days ago
How to clean white shoes properly?
Cleaning white shoes can help maintain their appearance and keep them looking fresh. Here's a step-by-step guide on how to clean white shoes properly:Materials you'll need:1. Mild soap or detergent2. Soft brush or toothbrush3. White vinegar or baking soda (optional)4. Water5. Clean cloth or sponge6. Old newspapers or paper towels Steps:1. Remove Loose Dirt: Knock your shoes together or use a brush to remove loose dirt and debris. You can also use a soft cloth to wipe away any surface dirt.2. Remove Laces: Take off the shoelaces. You can either clean them separately or replace them if they are too dirty or worn.3. Pre-treat Stains:If there are stubborn stains, pre-treat them with a mixture of water and a small amount of mild soap or detergent. You can also use a paste made from baking soda and water for tougher stains.4. Soak Laces:If you removed the laces, soak them in a mixture of warm water and mild soap. You can also add a bit of baking soda or white vinegar to help with stains. After soaking, scrub them with a brush or toothbrush, rinse, and let them air dry.5. Wash Shoes: Mix warm water with a small amount of mild soap or detergent. Use a soft brush or toothbrush to scrub the shoes gently. Pay extra attention to stained or dirty areas. Be careful not to use a brush with stiff bristles, as it may damage the shoe material.6. Rinse Thoroughly:Wipe off any soap or detergent with a clean, damp cloth or sponge. Make sure to remove all residue.7. Dry Properly:Stuff your shoes with crumpled newspaper or paper towels to help them retain their shape and absorb moisture. Let them air dry in a well-ventilated area. Avoid direct heat sources like radiators or sunlight, as this can cause the shoes to yellow.8. Clean Soles:Clean the soles of your shoes separately. You can use an old toothbrush or a small brush to scrub away dirt and grime. A mixture of water and mild soap or a specialized sole cleaner can be effective.9. Protect and Maintain: Consider applying a stain and water repellent spray to protect your white shoes from future stains. Regularly clean your shoes to prevent dirt buildup.10. Polish (for Leather Shoes):If your white shoes are made of leather, you can use a white shoe polish to restore their shine. Make sure to follow the instructions on the polish container.Remember, prevention is key. Try to avoid wearing your white shoes in muddy or extremely dirty conditions, and clean them regularly to keep them looking their best.
4/17/2024 7:05:52 AM •
Clothing...
Answered
3 days ago
How much would getting a wedding dress made cost?
The cost of getting a wedding dress made can vary greatly depending on factors like the design complexity, quality of materials, and the expertise of the designer. On average, it can range from a few hundred to several thousand dollars. It's important to consider your budget and discuss pricing with the designer to find the best option for you. For best designer lehengas, saree and ethnic wear you can check Mirraw Luxe online. Visit now: https://www.mirrawluxe.com/trends/wedding
3/8/2024 1:22:32 PM •
Clothing...
Answered
on Mar 08, 2024
Are you searching for Handcrafted Polki Jewellery in India?
Polki jewellery is a traditional Indian jewellery style that uses uncut diamonds in its designs. It is a popular choice for weddings and special occasions. There are many Indian jewellery designers and brands that offer handcrafted Polki jewellery, both online and in physical stores. Some popular options include Sabyasachi, Amrapali, and Tanishq.
2/25/2023 9:53:01 AM •
Clothing...
Answered
on Feb 25, 2023
What should I pay attention to when buying fashion jewelry online?
When buying fashion jewelry online, there are a few things you should pay attention to in order to ensure that you are getting a high-quality product:
- Material: Make sure to check what the jewelry is made of. Some common materials for fashion jewelry include gold, silver, and various types of metal alloys.
- Quality: Look for reviews or ratings from other customers to get an idea of the quality of the jewelry.
- Return policy: Be sure to check the return policy in case you are not satisfied with the product.
- Price: Compare prices with other retailers to make sure you are getting a good deal.
- Certification: If the jewelry is made of precious metals, look for certification from organizations such as the Gemological Institute of America (GIA) or the International Gemological Institute (IGI).
- Size: Make sure to check the size of the jewelry, as it may be difficult to return or exchange if it does not fit properly.
- Shipping: Check the shipping policies, including the estimated delivery time and any fees that may apply.
By considering these factors, you can make an informed decision when purchasing fashion jewelry online and be confident that you are getting a high-quality product. By the way if you want to buy Fashion Jewellery Online then you can visit on
Mangalmai Jewellers' website.
https://www.mangalmanijewellers.com/
I hope this answer is helpful for you. Thank You
12/17/2022 5:54:02 AM •
Clothing...
Answered
on Dec 17, 2022
