20 Most Recent
iHome Ih8 Dual Alarm Clock Radio For Ipod 9999 Pink Questions & Answers
Ihome--ih8,
I got the iH8 as a present everything works fine except for the ipod alarm. the unit will play my music when i press the play ipod button, and recognizes its plugged in, but when i set the ipod alarm, without taking out the ipod or anything, it doesnt go off with my music, it just buzzes. Idont think it is the ipod because i have updated the software on the ipod and have even tried 3 different ipods with the iH8. i have had the iH8 for about 2 weeks and set it nearly every day, and out of all those times it has gone off with my music only 3 times. How do i get it to work every time!??
How do I open my iHome IP46 to replace battery?
Looks like it was not designed to be repaired. You have to remove the speaker grills by prying them up. They are glued in. Then find 8 screws (not the small speaker screws) then you still need to pry it apart at the only seam that you can find that goes around the unit. The battery has three small phillips screws and it is unplug able. The only hint that they expected it to be repaired. It will be a mess at the seam when you finally get it apart using flat blades screw drivers (careful doing this). Now for the funny part. I unplugged the battery and plugged it backing and the unit turned on. Strange. Hope this helps. It actually has pretty good sound for its size. If I put it back together and it fails again, it will be trashed..
