20 Most Recent
Grundig Sonoclock 360 Questions & Answers
How to set the time
1. Press and hold down TIME.
2. Press HOUR briefly to set the hours step by step or hold it down to run through the hours quickly.
3. Press MIN briefly to set the minutes step by step or hold it down to run through the minutes quickly.
4. Release TIME to conclude the settings.
Thanks.
gylacz
5/12/2011 2:45:07 PM •
Grundig...
Answered
on May 12, 2011
Replacement battery for grundig satellite 3400 ? Where is it possible to buy?
I think this unit uses 'UM-1' batteries. They are also known as 'D Cell', 'R20' or 'LR20' batteries. Most good electrical, hardware and some of the larger 'supermarket' stores will have these batteries available. A good quality brand like Duracell or Varta should do the job. There is also two separate smaller 'button' batteries in the unit used to power the clock.
Grundig Radio - Smart ForTwo
Hi Carlie, I apologize, however I am not familiar with the code requirement for Grundig Radio. I recommend that you contact the dealership directly and they should be able to help you.
Sticky outside material on the Grundig G8, any solution?
Rubbing 70-90% alcohol applied on a piece of cloth then spread on the radio will eliminate the sticky substance. May need several application and vigorous rubbing. After the process, my Grundig G8 Traveller II looks better than the original rubbery texture. Cleaner too.
