20 Most Recent
Bushnell 22 Rimfire 3 9 x 32 Silver Riflescope MultiX Rimfire w 22 Questions & Answers
My name is james and
You backed it off too far and the alignment screw came out of the internal guide. They are usually pretty close to accurate when they are released from the factory. Make sure your mounts are in proper alignment and tight before trying to sight it in. 1 click is normally 1 inch at 100 yards.
Eyepiece assembly bushnell telescope
You never told us what model number or telescope TYPE you own. Is this a refractor or a reflector. ???
If a REFRACTOR usually you have a diagonal, the diagonal goes into the focuser and then the eyepiece goes into the diagonal.
On a REFLECTOR the eyepiece goes directly into the focuser.
Bushnell Tour v3 laser rangefinder will not display yardage
Please shutdown your device for 5 minutes, booot up and then check for yardage again. If this does not work, then you might look into the device manual (in troubleshooting) to check for an alternative approach to fixing this. Thank you.
