20 Most Recent Tivoli (PAL) AM/FM Radio Questions & Answers
Transformer to old PAL Tivoli been eaten by rats. Where to find another for this old model
Try radio shack in States, Maplin in the UKand other similar retailers elsewhere. Also, if you can identify it try ebay, they carry a lot of these parts
5/30/2015 12:18:05 AM • Tivoli (PAL)... • Answered on May 30, 2015
2answers
Pal speaker
you should read the catalogue.
5/8/2015 7:03:57 PM • Tivoli (PAL)... • Answered on May 08, 2015
The case has become sticky to touch
you need to replace cover assembly, try to check this link.
5/8/2015 7:00:21 PM • Tivoli (PAL)... • Answered on May 08, 2015
2answers
My Tivoli Pal radio casing has a sticky feel on
Just cleaned mine this morning because it was so ridiculously sticky and dirty with great success with nail polish remover and cotton pads. Read this solution posted elsewhere but was worried about ruining the finish, and there are warnings on the bottle about not using it on plastics......but tried a bit on the back. Went very well and with a load of pads and alot of scrubbing, it came completely clean! No sticky residue left, no discolouration. Looks brand new!
7/19/2012 12:50:59 AM • Tivoli (PAL)... • Answered on Jul 19, 2012
Bought a used iPal and
If the radio has a European-style plug, it's probably expecting 220-volt power since that's their standard. If you got a plug adapter but not a voltage converter, the radio won't work because the line voltage is too low.
Check the radio for a ratings label which will tell you for sure what the radio expects. There may be a selector switch on the back which will let the radio work on our line voltage. Otherwise you'll need to purchase a voltage converter to use the radio.
6/20/2011 1:43:09 AM • Tivoli (PAL)... • Answered on Jun 20, 2011
Radio will not play when turned on unplugged, but
I have the same problem with 2 Pal radio, I'm trying to find a solution, i think the trouble is in the switch to turn it on/off which has a bad electrical contact, I will tell you if I can find a solution. Phil
5/21/2011 1:47:54 PM • Tivoli (PAL)... • Answered on May 21, 2011
I thought the battery went dead so I bought a new
No! this is clearly a manufacture defect and I would return it, even if the battery failed the AC plug in would work, since you are having trouble with both sides the problem is in the actual radio.
2/19/2011 6:06:21 PM • Tivoli (PAL)... • Answered on Feb 19, 2011
Hello, I have a new battery but it does not seem
the battery is not being charged send it back to have its charging lines fixed
1/2/2011 3:04:36 AM • Tivoli (PAL)... • Answered on Jan 02, 2011
3answers
Antenna on radio broke
Radio Shack can get you an antenna, or a long wire (or wire coat hanger actually works too)
7/17/2010 2:30:52 PM • Tivoli (PAL)... • Answered on Jul 17, 2010
Radio operates when plugged into wall outlet. Can
You could probally change the battery, you would need to open the unit and get the battery number. Call Pro Line Music whit the volts and amps and physical size of the battery
12/11/2009 11:41:50 PM • Tivoli (PAL)... • Answered on Dec 11, 2009
Does the battery charge with the power off? or
Most units like this will not charge the battery because if the owner installs the wrong type of batteries it becomes a fire hazard.
Eric
9/23/2009 4:08:00 PM • Tivoli (PAL)... • Answered on Sep 23, 2009
Tivoli iPal
send it back! I have had 2 fail this way.
2/28/2008 9:38:07 PM • Tivoli (PAL)... • Answered on Feb 28, 2008
Tivoli Audio Model Two OFF - FM - AM - AUX Switch
It sounds like there may be a problem with the switch or the connections between the switch and the circuit board. Here are a few troubleshooting steps you can try: Clean the switch contacts: Over time, the contacts in the switch can become dirty or corroded, leading to poor or intermittent connections. You can try cleaning the switch contacts with a small amount of contact cleaner or rubbing alcohol on a cotton swab. Be sure to unplug the radio from the power outlet before attempting any cleaning. Check the connections: The switch may not be making a good connection with the circuit board, or there may be a loose wire or solder joint. You can try opening up the radio (if you're comfortable doing so) and checking the connections between the switch and the board. Look for any loose wires or solder joints, and gently re-seat or re-solder them if necessary. Replace the switch: If cleaning and checking the connections doesn't solve the problem, the switch itself may be faulty and need to be replaced. You can contact Tivoli Audio customer support to order a replacement switch and get instructions on how to install it.
2/24/2023 2:30:03 PM • Tivoli Audio... • Answered on Feb 24, 2023
Tivoli (PAL) AM/FM Radio Logo
33 questions posted
Top Tivoli Audio Players & Recorders Experts
John
John
Ngoro
Are you a Tivoli Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Tivoli Audio Players & Recorders
Most Popular Question
case become sticky touch
  • Audio Players & Recorders
