20 Most Recent
Liebherr KIU 1640 Premium Compact Refrigerator Questions & Answers
The fridge is not cooling,no fan noise but light on
Make sure that the compressor is working, You will need to take the fridge out and check the compressor motor for the start up on switch on > If not check the starter/contactor which could be defective and fitted to the motor. replace if faulty. Use a clamp tester or get help to finalise on this observation. Use a multimeter for checking for the voltage to the fan also. It might be possible that some rodents could have biten off your wires while you were out. so lets hope this is possible and so take a good look inside. If not check your compressor, starter. Good day
Liebherr freezer working, refrigerator doesn't
Take the cover off the fridge fan and put a flash light in there and a camera set to record. close the door for a couple of minutes and then look at the footage to see if the fan is running. The circulation fan should run all the time.
4/5/2023 4:16:50 AM •
Liebherr...
Answered
on Apr 05, 2023
LIEBHERR CBNes 39560 Fridge - ice in the drainage trough on the back?
Question edited for correct spelling of the maker.
Question moved to maker category.
Check the temperature of the fridge with a digital thermometer. I should be 5' centigrade. It may be set too cold and freezing condensation running on the rear wall. Also make sure the circulation fan is working. It looks like it is the round disc at the top rear.
Push a flexible net curtain wire down the drain until it appears above the compressor pan.
You can also try cleaning the drainage trough, dry it and spray it with dry silicone spray or even WD40 if you don't mind the smell. That will stop water sticking.
https://mediamarkt.pl/agd/lodowka-liebherr-cbnes-39560
3/29/2023 5:02:00 PM •
Liebherr...
Answered
on Mar 29, 2023
Liebherr cnesf 5013 superfrost always beeping
Maybe it is only in the settings, I don't know the details of your ref but I would like to suggest to consult it in the technical experts.... because you said, it is turning on and off but it is working, maybe you only mistakenly click some button but if not, the refrigerator is the problem ( if it is new one, you can return it and replace a new refrigerator but in this case, you need to check it before replacing another one)
10/29/2021 4:02:51 PM •
Liebherr...
Answered
on Oct 29, 2021
Liebherr fridge stops working after 1 hour.
The Spaminator Mar 22, 2021
Hi Jasmin Black, I suspect ice build up behind the back panel of the freezer could be causing this. this could be due to a faulty thermostat transducer that tells the freezer to defrost when the ice builds up.
3/22/2021 10:25:01 AM •
Liebherr...
Answered
on Mar 22, 2021
