20 Most Recent
Manfrotto 679B Monopod Questions & Answers
Reassembling telescopic sections for a 676B monopod
Each leg lock has a leg locking lever and a screw that hold the clamp assembly tight to the leg. Unlock the leg lock lever, loosen the screw above it that holds the clamp tight to the leg. The legs should fit into each other sice each leg is slightly larger or smaller then then next one. Slide the clamps in the approprite places and tighten the screw enough to hold the clamp assembly tight, but do not over tighten it. Over tightening will damage the 679 tubes.
685B Monopod
If In melbourne look up www.adeal.com.au . They are wholesalers and DO NOT sell to the public, but if you go out to them in Altona North they will help you over the counter. Or go to any TED's Camera Store. They sell the range of Manfrotto tripods and they will be able to help you.
I cannot get my MHXPRO 2 w fluid head off my manfrotto 055 tripod both brand new. I have tried to follow the instructions but without succes
Try removing the centre column, then clamp it securely in a vice (or vise, if you prefer), packed with wooden battens to prevent damage.
Ensure that all the locks on the head are secured tightly. Then rotate the head counter-clockwise, and it should unscrew from the thread at thye top of the centre column.
If it still won't shift, try spraying a little WD40 or other such lubricant at the place where the head attaches to the centre column, leave it to soak in, then try again.
If you still have no luck, hie thee to thy local repair facility and humbly beg assistance from the artificer.
10/19/2016 8:38:32 PM •
Manfrotto...
Answered
on Oct 19, 2016
How do I switch the Manfrotto RC322C2 from right to left hand use?
I've looked at the spec, and it does not appear to be changeable, unfortunately. Unless you are absolutely wedded to the idea of using that particular head, there are others in the range that can be used with either hand. Check out the selection here :
Amazon co uk manfrotto headsThe one I use, for both stills & video, is the 804RC2. There are three handles, one for adjusting in each dimension, the main two being easily accessible from each side. Takes the standard Manfrotto Q/R plate as well.
10/7/2016 10:35:11 PM •
Manfrotto...
Answered
on Oct 07, 2016
How adjust the vertical viewing
are you just mounting a camera to the tripod itself? - you need to purchase a head as well - the head screws onto the top of the tripod, and then the camera fixes to the head, usually with a qr plate.
1/21/2015 3:08:09 PM •
Manfrotto...
Answered
on Jan 21, 2015
Convertible center column
Depending upon which model you have it could be as simple as turning the center column upside down. Without more info about the tripod this is the best I've got.
10/21/2014 7:24:41 PM •
Manfrotto...
Answered
on Oct 21, 2014
Tevion helpline line
That is going to have to be disassembled and then re assembled. You can send it to:
Repairs at SpartanPhotoCenter
108 Garner Rd
Spartanburg, SC 29303
10/21/2014 7:18:17 PM •
Manfrotto...
Answered
on Oct 21, 2014
How should a Manfrotto fluid head be stored? Up or down
It shouldn't make a difference either way. The "Fluid" is so viscous and sticky that gravity is not going to be a factor. The "fluid" is trapped between interlocking disks, so it doesn't go anywhere. Avoid extremely high tempertures. That will cause the "fluid" to run. Just make sure you keep grit and dirt out of the working parts and your Manfrotto head should work for years.
7/15/2014 9:22:28 PM •
Manfrotto...
Answered
on Jul 15, 2014
