20 Most Recent
Biostar G41M7 Motherboard Intel Pentium Dual Core E5300 Processor Bundle (G41M7 WBX80571E5300) Questions & Answers
I CAN NOT SELECT JUMPER RESET CMOS
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart this will reset cmoshope this helps
After installation of Biostar G41-M7
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Biostar i945cm7b
best is noobs avoiding UEFI
and 945 is 2005 tech, not modern UEFI bios .at all
but do ask maker this.
but 945 ended there.
6/6/2022 1:34:56 PM •
Biostar...
Answered
on Jun 06, 2022
Mainboard Vestel 14MB02-03 no power
posted to computer repair help, PCwhat computer is this, not toldVestel 14MB02-03 (mobo labels useless)Vestel made this mobo under contract to an OEM PC maker,. like BIOSTAR? or who? not told really.Vestel does not sell PCs ! google shows no hits (zero). posted wrong PC model?ahhhhh coded words off mobo white painted silk screenssureI see one hit on that number alone and shows LAPTOP PC MOBOclearlyok , why post mobo models. and not real maker of PC laptop model, did you somehow lose the laptop casings.??>???????????odd odd post this is, like that. we fix PC by makers name and real models. not mobo codes. sorrythe model is on the bottom tab on laptops oldor in bios screen 1 toldnow and answer for laptops old. 1: big battery dead and worse shorted making PC dead, remove it run on AC power pack only,see it works.2: coin cell dead, sure it is that old replace it.3: any of up to 20 other modules inside shorted out.4: stuck in sleep mode dead, push power button for 10 seconds and release, runs now?5: LCD CCFL back lamps dead, use a flash light pointed to screen to see data turned on, if seen the CCFL is dead.(aka, background light tubes)
6/6/2022 12:42:55 PM •
Biostar...
Answered
on Jun 06, 2022
Audio Adapter ESS Technology ES1938/ES1941/ES1946 Solo-1(E) AudioDrive for windos 7
no PC told no OS told but it was for XPbiostar ended support. windows 7 is oct 2009 OSthe old XP driver is here.https://www.majorgeeks.com/files/details/ess_sound_card_es1938es1946_(es1969).html2006 sound cards. it is PCI not PCI-expressso is useless on all modern PC>but since you imply it fits to a PC the PC is a relic and not told the chip sets on the card are not supported by them maker of the chips so is double dead.(product line not maker)https://www.esstech.com/as you see no es1938 era support.if you google things that do not exist the prize is a nasty virus, here is a short test for w7 just for you.the waybackmachine.com shows https://www.esstech.com/going dead (for legace) 2007so dead 2 years before w7 was released.XP lasthttps://web.archive.org/web/20070202023729mp_/http://www.esstech.com/techsupp/drivers.shtmas you can see the FTP links to the drivers are dead.for ever and ever.now to w7 year, 2009 dec, 2 months from w7 releasetiming is everything , no?the endhttps://web.archive.org/web/20091213143106/https://www.esstech.com/they ended all legacy then./ that means so did biostar. with no base drivers it ends.RIP ESS legacy.
5/17/2022 7:12:49 PM •
Biostar...
Answered
on May 17, 2022
MP6PB M2 DRIVER
asked 1000 times learn to search here? OR
1001
GOOGLE BIOSTAR HOME
GO THERE
5/17/2022 6:39:51 PM •
Biostar...
Answered
on May 17, 2022
K8m800 am2 la motherboard schematics
there are no schematics ever.
yes mobo connectors all and more.
in the manual
learn to google first.
google Biostar home
this gets you the correct web site for you country,
then RTM.
5/17/2022 6:38:49 PM •
Biostar...
Answered
on May 17, 2022
Manual ms-7050 ver:2.0
GOOGLE BIOSTAR HOME
GO TO your countries support paGE THERE.
LEARN GO GOOGLE
FOR MANUALS OR DRIVES AND all
5/17/2022 6:25:59 PM •
Biostar...
Answered
on May 17, 2022
Finger scan
I never use that for that reason.
nor eyeball scans .
or DNA scan
only biostar can fix that.
sing the huppty dumpty song,
think it trough if easy to hack the feature is worthless.
see???????
buy it locked did you ,not told.
5/17/2022 6:12:53 PM •
Biostar...
Answered
on May 17, 2022
Biostar board usb boot
post a question please.
if I do wild dreams in my head I think (ESP)
my pc will not boot from USB?
and the boot order is wrong!
or usb ports in bios are disabled !
or USB port in bios set to NOBOOT!
or the unstated mobo is so old i can not do this, none told
5/17/2022 5:27:16 PM •
Biostar...
Answered
on May 17, 2022
Schema ps2 50004
no mobo told , no PC told no problem or goal told.
P/s2 mouse or keyboard? pin outs.?
if you wiki that the answers is here, for sure.
personal system 2, IBM devices?
or sony PS2 play stations.
hummmmmmmmm i vote IBM but I,m jaded.
5/17/2022 5:24:19 PM •
Biostar...
Answered
on May 17, 2022
