20 Most Recent ASUS M4A78LTM LE Motherboard Questions & Answers
I have got an "Asus
Download the Drivers direct for Manufacturers website or Google search.
9/3/2017 1:32:10 PM • ASUS M4A78LTM LE... • Answered on Sep 03, 2017
2answers
I have an asus M4A78LT-M
The yellow question marks on the various devices indicate that the drivers for these devices have not been installed. When you install these devices then the error messages will not appear and the yellow question marks will be gone.
You can download the drivers from ASUS WEB site. Selectyour model motherboard/computer/laptop, and make sure you select the Windows XPor Vista version of the drivers that matches your Windows operating system.Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
11/7/2012 9:11:22 PM • ASUS M4A78LTM LE... • Answered on Nov 07, 2012
Lan port connection fail?
you will need to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled If you are trying to connect through a modem/router the driver should have come with a disc provided by your ISP internet service provider or your motherboard disc click start control panel administrive tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers also make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabledimake sure its enabledPci device arrows key scroll to nstalled. hope this helps
5/24/2012 2:28:33 PM • ASUS M4A78LTM LE... • Answered on May 24, 2012
2answers
Do i need to by
No, you do not need a video card because that motherboard has graphics integrated on the motherboard. The motherboard has the following video processor built-in:
Integrated ATI Radeon™ HD 3000 GPU
Feel free to let us know if you have further questions.
Thanks!
EJ Kudelka
9/7/2011 5:05:50 AM • ASUS M4A78LTM LE... • Answered on Sep 07, 2011
How to update the bios?
Hi, you need to download this:
ASUS Update V7.18.03 for Windows XP 32bit/XP 64bit/Vista 32bit/Vista 64bit/7 32bit/7 64bit
From here:
http://www.asus.com/Motherboards/AMD_AM3/M4A78LTM_LE/#download
You may need to unzip the file before installation
Its the easyest way to upgrade the bios.
Here is a small youtube video that shows you how:
http://www.youtube.com/watch?v=NWf3OLiBh70
Hope this will help you.
8/17/2011 4:19:33 PM • ASUS M4A78LTM LE... • Answered on Aug 17, 2011
Installed new Asus M4A78LT-MLE, when
It sounds like you have upgraded from another board to the M4A78LT-MLE and you have not reinstalled windows. If this is the case then are going to have terrible troubles with drivers and lock ups. Believe me, reinstall windows a fresh then install your drivers then windows updates and all will be well. Oh by the way use the asus site for the latest drivers and not those on the disk that came with the motherboard.
8/14/2011 5:20:23 PM • ASUS M4A78LTM LE... • Answered on Aug 14, 2011
I've bought new pc with
Hey there. Your motherboard is most likely faulty and is causing shorts inside the keyboards and mouses. You should get a replacement from your retailer for the motherboard.
Have fun :)
8/14/2011 2:28:53 PM • ASUS M4A78LTM LE... • Answered on Aug 14, 2011
2answers
Are necessary the driver for
Yes you must install all of the drivers for your mainboard, necessary drivers are Audio, Ethernet and Graphics drivers. Drivers enable those controllers to function.
The drivers can be found on the CD that came with your mainboard.
Take care!
damnor01
8/14/2011 9:39:53 AM • ASUS M4A78LTM LE... • Answered on Aug 14, 2011
I have same problem. this
Hi, you can take a look at this site:
http://uk.asus.com/Motherboards/AMD_AM3/M4A78LTM_LE/#CPUS
This is the cpu list that your mainboard supports.
Remember the ram module have to fit the cpu also.
8/12/2011 9:51:09 AM • ASUS M4A78LTM LE... • Answered on Aug 12, 2011
2answers
AMD Phenom-II is installed in Asus M4A78LT-MLE
the only phenom-II cpu's it supports are the 545 and 550 socket am3 1.01ghz. if you have anything other it will not run. here is complete cpu support list here
4/19/2011 2:10:18 PM • ASUS M4A78LTM LE... • Answered on Apr 19, 2011
2answers
My internet speed has been reduced to 1mb from 3
use speedtest.com site to verify download is stuck at 1mb
then check the lan settings for the hardware
goto control panel system and check the properties on your lan device
10mb could do this.. maybe
4/6/2011 7:36:05 PM • ASUS M4A78LTM LE... • Answered on Apr 06, 2011
2answers
I got asus mboard m4a78lt-mle
Hi you need to update the bios :-)
Regards
4/2/2011 5:53:16 AM • ASUS M4A78LTM LE... • Answered on Apr 02, 2011
I've just installed my new Asus M4A78LT-M
http://www.asus.com/product.aspx?P_ID=exJL00uovTJaDqxR
http://support.amd.com/us/Pages/AMDSupportHub.aspx
The first link is an Asus site where you can get the most current drivers. The second site is AMD's site where I would go to download your drivers. The fact that you don't have any display is probably because of the way it's hooked to monitor or when you hooked it up or, if you changed the way it was hooked up. Try diconnecting monitor/lcd from back of computer and plugging back in, then restart. If that doesn't work, if you ever had a picture, see if you can do a system restore to when you did have a picture. If you get a picture, uninstall all software through Programs and Features. If you have Catalyst Control, do an Express uninstall to remove all hardware. For new hardware, go to second link(AMD drivers). In the top right corner there is a window"Download Drivers",
1 Componenet Catagory-click on arrow on right, scroll down and select "Motherboard/chipset and select
2 Product line-click on arrow, scroll down and select"Radeon 3xxxx series and select
3 Product Model-click on arrow and select"Radeon 3000 Series"
4 "Operating System" click on arrow and select your system.
Click on "Show Results". This will list your drivers. Click on first one to download. It will ask you for either "Express" or "Custom" install click on "Express". Finish download and restart.
3/9/2011 1:29:03 PM • ASUS M4A78LTM LE... • Answered on Mar 09, 2011
Hang autometicaly while work for
you have a cooling problem
just open ur pc case form 1 side
and see
how many fans u have in ur com
or contact hardware retailer
2/21/2011 11:13:07 AM • ASUS M4A78LTM LE... • Answered on Feb 21, 2011
I have a m4a78lt-m motherboard will kingston ddr3
This motherboard uses DDR3-SDRAM, ECC and non-ECC, unbuffered, PC3-10600(1333mhz) or PC3-8500(1066mhz), dual channel architecture (two sticks at a time), and a max memory of 8Gs.
This are the specs for your ram: 4GB 1600MHz DDR3 Non-ECC
(Kit of 2) Intel XMP HyperX = DDR3-1600
Default = DDR3-1333 CL9-9-9-27
CL9-9-9 1.65V
1.5V
In other words, Yes! This should work just fine. The ram will just run at its default speed of 1333mhz.
1/28/2011 8:36:32 PM • ASUS M4A78LTM LE... • Answered on Jan 28, 2011
ASUS M4A78LTM LE Motherboard Logo
32 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
lan port connection fail
  • Computers & Internet
