20 Most Recent
Intel DH55TC Motherboard Questions & Answers
Is my gigabyte gtx 470
The Gigabyte GTX 470 should be compatible with the Intel DH55TC motherboard if it has a PCIe x16 slot, which is the standard slot for graphics cards. However, there could be various reasons for your PC not turning on, including:
1. Power Supply: The power supply could be inadequate or malfunctioning. Make sure your 600W power supply is sufficient to power both the motherboard and graphics card.
2. Connections: Ensure that all power connections, both on the motherboard and the graphics card, are properly seated.
3. Drivers: Sometimes, improper or outdated drivers can cause issues. Ensure you have the latest graphics card drivers installed.
4. BIOS/UEFI Settings: Check the motherboard's BIOS/UEFI settings to ensure that it's configured to recognize the graphics card and not use onboard graphics (if available).
5. Faulty Hardware: It's possible that the graphics card or motherboard itself is faulty. Testing the components individually in another system may help identify the problematic part.
6. Power Consumption: The GTX 470 can be power-hungry. Ensure that the power supply can deliver enough amperage on the +12V rail for the graphics card.
7. PCIe Slot: Make sure the graphics card is properly seated in the PCIe x16 slot and that there are no physical obstructions.
Given the replacement motherboard also stopped working, it might be worth checking the power supply's quality and output, as it could be a common factor in both motherboard failures. If possible, try the graphics card in another system to see if it functions correctly.
Bios setup
Then remove it and try in a different slot. or try a different Stick.
Dh55tc warranty check
do the following steps to rectify your problem.1.if there are any beeps. clean your ram and reinsert it.2.check the power cord of your monitor and make sure you have a working monitor.3. else buy a vga card if the onboard vga slot is malfunctioning
If ram memory increased the graphic will be good on intel dh55tc motherboard?
Anything over 3GB on a 32 bit operating system is unavailable. The motherboard will take 16GB - so 4GB per slot I always use Corsair Ram and have not had any problems in the last 10 years. From the look of the spec Ram will not affect the graphics as it needs a separate Graphics card. get one with the highest number of "Stream Processors".
I have Intel DH55TC Mother
Always Provide Proper Details.
1. Processor
2. Motherboard
3. RAM With Company Name
4. Graphics Card Detail
After Reading Ur Comments I Want 2 Know How Many Beeps You Hear....
Beep Details.......
2 Beeps Shows Graphics Problem
Use PCI-E Graphics Card Like ATI OR NViDiA.
3 Beeps Shows RAM Problem
Use Another RAM OR Try The RAM In Another Slot OR Channel.
Hope This Helps....
