20 Most Recent Gigabyte GAX58AUD3R Motherboard Questions & Answers
Ga-x58a-ud3r the pwr led
that is custom system like mine a DIY build and custom unstated case., bought as new case only I bet of vast. and if built wrong it fails. the LED is where the POWER on LED wired wrong is it. the Power on led does flash wired correctly for sleep mode. if wired wrong is now the HDD activity LED, and should flash x58 is good chip set, pure intel it is usb3 chip NEC needs good driver so watch out there. pwr_on LED goes to pins 2 and 4 only on the header. page 30 in linked manual if is wired correctly the led is called MSG MSG/PWR (Message/Power/Sleep LED, Yellow/Purple): and Connects to the power status indicator on the chassis front panel. The LED is on when the system is operating. The LED keeps blinking when the sys-On is in S1 sleep state. The LED is off when the system is in S3/S4 sleep Blinking state or powered off (S5) so the manual told you blinking is S1 power state ACPI. other causes bad LED (power button) loose wires at mobo end of that or at power switch. mobo bad, here, rare as hens teeth if user did not jumper DC power to this LED pin and blow the driver transistor up. guesses wild does that. BIOS controls (you set it) soft power off , instant off or off. mode. no case told some are dead wrong here, some cases , use a 2 way LED for power, and is 2 LED wired in parallel and reversed to get 2 colors . and fails on simple mobo. not using bipolar controls to LED. NO CASE told so NO JOY , 10,000 cases made or more that the same but generic cases do work if is that, not OEM cases..
6/4/2022 1:26:21 PM • Gigabyte... • Answered on Jun 04, 2022
I've just installed the GA-X58A-UD3R
You may go on line to Tweaking.com and download their Windows repair program (Free Version) as this program digs deep into all areas of the computer. The reason I suggest that is because some of the code used to locate hardware and various functions are fixed. If the motherboard is new, the BIOs are up-to-date or more recent and they should locate the devices at boot time. Other than that, replace the MB as long as its under warranty.
2/6/2018 5:57:42 PM • Gigabyte... • Answered on Feb 06, 2018
Putting together a new desktop
Check to see that you have adequate thermal paste and that you're connected to the onboard graphics first. It may not detect the GPU on an expansion card just yet.
10/24/2017 4:10:39 PM • Gigabyte... • Answered on Oct 24, 2017
Keyboard does not work during boot, can not get to BIOS
Hi try using a ps2 keyboard
12/21/2011 12:41:37 AM • Gigabyte... • Answered on Dec 21, 2011
0answers
GA-X58A-UD3R what ram does it support ????
Each memory slot can hold DDR3 PC3-10600, DDR3 PC3-8500, DDR3 PC3-12800, DDR3 PC3-17000, DDR3 PC3-14900 with a maximum of 6GB kit (2GBx3) per slot.*
  • 240-pin DDR3 DIMM Banking: 6 (2 banks of 3)
  • Chipset: Intel X58
  • DDR3 SDRAM Frequencies: PC3-6400, PC3-8500, PC3-10600 and PC3-17600
  • Error Detection Support: Non-ECC only
  • Graphics Support: Quad PCI Express x16
  • Max Unbuffered DDR3 SDRAM: 24576MB
  • Module Types Supported: Unbuffered only
  • Supported DRAM Types: DDR3 SDRAM only
  • USB Support: 2.x and 3.x Compliant
  • From crucial.com
    12/19/2010 3:30:12 PM • Gigabyte... • Answered on Dec 19, 2010
    Computer shuts off before getting to bios? HELP
    Replace your PSU power supply unit then test all leads that are attached to your hard drive including electrical extensions sounds like a faulty lead of some sorts then
    hope this helps
    9/15/2010 11:37:07 PM • Gigabyte... • Answered on Sep 15, 2010
    4answers
    I dont able to format my pen drive when i open it
    Hi
    First u attach your pendrive with pc after that u do a right click on pen drive folder ,then u click on scan option then the scan folder will apper and u select the pen drive folder by adding ,then click on next opyion and wait untill the scan is over .After scan over's then u can format your pendrive....
    Thanks for using fixiya
    Rupesh Kumar
    12/18/2023 12:36:15 PM • Gigabyte... • Answered on Dec 18, 2023
    Why my Gigabyte GA945GCM-S2C board GPU heat instantly
    If it is not an accumulation of dust and if your fans are working properly and your ventilation is not blocked, that there was not a built-in cooling system for this integrated part makes me wonder what is going on. One would have thought it suggested such was not necessary. How old is the thermal paste in the computer? I would replace that before trying more desperate measures. Rather than presume the fan was working, I'd make sure that it was. Here are some causes and fixes: https://www.onecomputerguy.com/gpu-overheating/
    10/15/2023 4:39:50 PM • Gigabyte... • Answered on Oct 15, 2023
    Hey, I own gigabyte W566N
    1/5/2023 3:23:38 AM • Gigabyte... • Answered on Jan 05, 2023
    Ati radeon hd 7770 problem
    no PC told at all no OS told either. sure a DESKTOP sure. no monitor told nor cable used, VGA, DVI,hdmi, DP i can not see your near black screen at all. cold booted is the PC splash screen dead./? all bios screen dead and all BIOS works even with HDD missing. idle black is sleep mode, a USA law mandates that. iof we do not like sleep mode we disable it in power settings CP CP means control panel this must be your first PC ever? and all go to sleep ,go to walmart see them all in sleep mode now, yes, a USA law called Energy star laws. and all wake up on demand new , unmolested. wiggling the mouse or hammering the space bar ends sleep but not if (again) power settings has USB going to sleep too. why post lacking Pc makers name and OS.windows what gee vast persons on earth ugraded w7 top 10 and now this fails. due to , PC maker told you , no w10 support in this secret PC 4 decades of 100,000 models of PC I can no no guess blind./ Radeon hd 7770 card and 80watt card in fact, oops.????? is this real ATI/AMD card or any of the other 12 makers of cards. ??????????? no full card number told and guess what the watts matter. 250watts is smallest watt PSU, or more if PC is loaded out like mine with 2SSD and 4 SSD and 1DVD and 1 Blue ray and max ddr and more. Power is first after fit, and yours fits so power is next PSU watts and what the card needs let me see that. all hits on this card show it crosses the magic 75watt rule for PCi-2 power of 75watts, and card is 80watts and more dynamically so they maker of the card has a 6 pin 12vdc aux jack that can not be ignored or the card fails, so is that wired up? as it must? yup top rear of card 6 pin aux power in black , steathy that, hard to see at 1st glance but 80watt cards need it, that and even 300watts cards are sold. does your card have red fan. see what I mean buy 12 maker of cars all with AMD GPU. the cards all have tag called the SKU tag or full model told for GPU speed and vram sizes and more, lots more. https://search.brave.com/images?q=%20Radeon%20hd%207770%20card# I have boxes full of old GPU cards here, stored. some need 500watt more PSU to even begin any 3d mode. only the SKU matters, wiki SKU. and what PC this is and what PSU wattage and if said PSU has the 2 AUX CABLES WITH DUAL 6/8 Plugs, (PCI-12v) marked. if not we can do adapters easy. ask
    6/4/2022 4:14:14 PM • Gigabyte... • Answered on Jun 04, 2022
    My soundcard is not working while using 8vm533m-rz model gigabyte mother board in windows 7
    so the PC mobo has and addin, PCI card sound"? 2004 PC mobo relic, now and 13yo to you. no card told. (fail)(buy only w7 allowed card if must) you did say CARD so means NOT ON-BOARD sound chip. relic P4 PC. mobo v1.0 mobo? this trash mobo uses EOL DOA, via chipsets, that do not allow w7 Integrated Realtek ALC662 audio CODEC chip this chip set is dead too, from maker realtek. if you knew that, and added a secret sound card. this mobo only does windows 200o to XP says so on page one at gigabytes this mobo. so w7 does not belong hear unless replacing every thing there that fails 1 by 1, , pain. ive done this vast times, for folks willing to. last xp driver is here for realtek https://www.gigabyte.com/Motherboard/8VM533M-RZ-rev-10/support#support-dl-driver as a rule only this OEM maker PC can make there sound chips work (as a team of parts) not simple as many think, even has mixer chips and more, all custom to maker. yes cards work better, on this mobo the VIA chip and codec chip must work or sound will be dead. and is common this. lacking no vista driver up, ever/ this mobo has no SATA ports nor any PCI express card slots at all. and finding PCI (non express) cards that can run w7 can be hard. for sure now. yes possible, with careful searching specs of relic PCI cards. also the VIA chip dead makes The ethernet port dead too. and usb dead and IDE drives dead,vista up. never buy VIA chipped mobo. or pain is all there is. no drivers.
    6/4/2022 2:16:57 PM • Gigabyte... • Answered on Jun 04, 2022
    Gigabyte GM-M5050 not connecting to laptop.
    it is only a USB mouse and works on any pC really. w7 needs no special driver for this mouse ever, it uses PnP, plug and play and the internet must be active and working for PnP to work is it? not told that. your failed computer is all messed up with w7 even infected monza is w7, 2012 made (year) the usb ports are first not mouse the device manager must show all USB ports have good drivers, and you test them using a USB stick of thumbdrive memory to be sure they do work, and if does good or use USB keyboard to test usb ports all if all that works then the mouse is tried. and internet connected and the mouse to when connected must show up in device manager. and actually function/
    6/4/2022 1:34:15 PM • Gigabyte... • Answered on Jun 04, 2022
    Hi i have a gigabyte
    talk to gigabyte.com is the cooler not from gigabytes is that it? so is this below? i guess you meant Model# GZ-FW1CA-AJS go back to air or upgrade to far better cooling this is not. cheap cooling is no good. will not last. also above is know for bad corrosion inside, rule #2 buy cooling only from makers that see spare parts for it. or is doomed. the manual shows no parts list for sure water level so needs new water tank I guess, why not ask maker for support no PC store sells parts for this custom case.(turn key is seems) or defeat that switch and just look at level at step 1 , before turned on. (that is what I would do, but sure back to AIR
    6/4/2022 12:43:46 PM • Gigabyte... • Answered on Jun 04, 2022
    I need a Gigabyte G41 s2pv rev1.3 circuit diagram pdf
    the mobo is fully covered at Gigabyte.com we are not them more have 10,000 manuals here. at all this https://www.gigabyte.com/Motherboard/GA-G41MT-S2P-rev-13#ov its all there to read, 24/7 form 2010 to 2022 still. the audio may be dead on newer oS as audio chip maker went EOL Dead. w7 is max.
    6/4/2022 11:59:43 AM • Gigabyte... • Answered on Jun 04, 2022
    Changed out atx power supply because computer not powering up. Do I replace with same motherboard with same or buy new Windows 10 Box.
    ok, a simple hardware question only. w10 could careless about PSU. (facts) mobo is micro atx size 24.4cm x 24.4cm not powering up has many causes, even simply stuck in sleep mode. (power on button held for 10seonds and released last is 1 cure. of about 20 causes (up to) GA-F2A78M-D3H (rev. 3.0)or rev. 4.0????? rev is on bottom left of mobo, normal tower case. no case told the PSU is called ATX and all work here 500 to 750watts 24 pin power is normal but CPU power uses 8 pin power plug PSU.marked ATX12v psu lacking 8 pin, can use 4 to 8 adpater. vast here work, in real ATX case not micro cases. https://www.newegg.com/p/pl?d=psu+atx&N=4131%20100007657%20600014006%20600479294&isdeptsrh=1&Order=1 from you manual . 12vatx-undefined-undefined-0.jpg dead PC are all fans dead.> that is dead PC. the monitor must be good and connected the the VGA jack if using GPU card then it must connect to the monitor the BIOS screen must work or the PC is dead or GPU card is dead. strip the PC down ,any thing in the PC shorted will make PC dead. if strip down tests fail the PSU may be bad is its fan dead too? both power connectors most be connected above or PC will be dead.
    6/4/2022 11:51:20 AM • Gigabyte... • Answered on Jun 04, 2022
    My gigabyte motherboard how to check warranty
    gigabyte.com ask them only. the records are secret , them to you only based on serial number of the mobo. do not post serial numbers or risk losing your warranty. learn to go there, only.
    6/4/2022 11:29:36 AM • Gigabyte... • Answered on Jun 04, 2022
    I915p/i915G VGA driver free download
    Visit the following link. https://downloadcenter.intel.com/product/50364 Select the required driver and download.
    6/3/2022 3:25:21 PM • Gigabyte... • Answered on Jun 03, 2022
    I am using GA-945GCM-S2l Gigabyte motherboard for my desktop and Windows 7 32 bit OS. The hard disk 250 gb is not working. Will this motherboard support 500 gb SATA hard disc? Bhasker Raj Bangalore India
    That motherboard has 4 SATA 2.0 slots. Should work well. You said "hard drive" so I am assuming you do not mean Solid State drive (SSD) I am surprised you are using Windows 7 with that MB
    6/3/2022 12:04:09 PM • Gigabyte... • Answered on Jun 03, 2022
    0answers
    Gigabyte GAX58AUD3R Motherboard Logo
    13 questions posted
    Top Gigabyte Computers & Internet Experts
    MegaByteMe
    MegaByteMe
    Grand Canyon Tech
    Grand Canyon Tech
    SmartAviator
    SmartAviator
    Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
    View Most Popular
    • Gigabyte Computers & Internet
    Most Popular Question
    ga x58a ud3r pwr led
    • Computers & Internet
