20 Most Recent
Pioneer DVRA18M 22x DVD RW Drive with LabelFlash (Doublelayer) DVDRAM R RW 22x 8x 16x (DV Burner Questions & Answers
How to take off face plate pioneer PVR 9200 DVR
You will need to remove the drive from the chassis first. Then take a long slender probe and insert in the hole to release the media tray. Once the tray is extended you will be able to pry the face plate off by pressing the tabs that click it in place.
Pioneer dvr-h-k is frozen
You didnt say which model. They are v bad machines. Too much stuff, and trying to be International video. Try this
http://bootstrike.com/Articles/DVR-530H-S/
Pioneer AVH- p 2300 wire pinout for power plug
Here is the wire pinout for the power plug of the Pioneer AVH-P2300 car stereo:
- Yellow: Constant 12V (Battery)
- Red: Ignition 12V (Accessory)
- Black: Ground
- Blue: Power Antenna Control
- White: Front Left Speaker (+)
- White/Black: Front Left Speaker (-)
- Gray: Front Right Speaker (+)
- Gray/Black: Front Right Speaker (-)
- Green: Rear Left Speaker (+)
- Green/Black: Rear Left Speaker (-)
- Purple: Rear Right Speaker (+)
- Purple/Black: Rear Right Speaker (-)
6/25/2023 1:35:19 AM •
Pioneer...
Answered
on Jun 25, 2023
My pioneer pro 151fd TV won't play sound
- Check the volume level: Make sure that the volume on the TV is turned up and not muted. You can try increasing the volume level and see if that resolves the issue.
- Check the audio connections: Ensure that all the audio cables are properly connected to the TV and the external audio device (if you're using one). Check if the cables are damaged or loose, and try reconnecting them to make sure they're secure.
- Check the audio settings: Ensure that the TV is set to output audio through the correct device, whether it's an external soundbar or a home theater receiver. You may need to access the TV's audio settings to adjust this.
- Check the external audio device: If you're using an external audio device, ensure that it's properly connected and powered on. Try switching to a different audio input on the device and see if that resolves the issue.
- Reset the TV: You can try resetting the TV to its default settings to see if that fixes the issue. Refer to the TV's user manual for instructions on how to reset the TV.
If none of these steps resolve the issue, there may be a problem with the TV's internal audio components. In this case, you may need to contact Pioneer customer support
2/16/2023 8:56:31 PM •
Pioneer...
Answered
on Feb 16, 2023
Pioneer dvh-3490ub aux2 mode how to setup
hi
1 Press M.C. to turn AUX1/AUX2 on or off. the dimmer on or off. 1 Press M.C. to turn dimmer on or off.
- Press M.C. to display the setting mode.
- Press M.C. to select the segment of the clock. display you wish to set. Hour-Minute.
- Turn M.C. to adjust the clock.
12/1/2021 4:04:49 PM •
Pioneer...
Answered
on Dec 01, 2021
Can i download navigation to the double din pioneer AVH- P4000DVD
Sorry but no Navigation Suppourt, however you can use your iPhone or iPod/iPad's Maps or your choice of Navigation App to see Navigation Instructions and Features on Screen, compatible with Android as well. I'll attach a link and a few pics, mo Navigation Suppourt but nearly everything else. No Navigation in Menu or Inputs for Navigation Antenna on Rear with all other inputs. Check it out and see what option you like best. I'd use screen mirroring and go the iPhone route(or android if Apple isn't your preference).
Thanks and Good Luck, if this has been helpful please click the icon to let me know it has been and feel free to leave a review or follow me as I answer auto/mechanical/technical questions primarily and may be helpful again. Thanks again- Daniel
1/14/2019 4:31:56 AM •
Pioneer...
Answered
on Jan 14, 2019
