20 Most Recent
LG GH24NS50 DVDRAM Burner Questions & Answers
Como bajar los drivers
http://www.pcpitstop.com/drivers/download/HL-DT-ST~DVDRAM~GH24NS50~ATA~Device.html
drivers are on that page
He can support lightsribe?
tank
According to the following features:
•SATA Interface
•MAX. 24x DVD±R Write Speed
•SecurDisc™ Technology
•RoHS Compliant
•CD-R/RW, DVD-R/RW/RAM/ +R/RW +/-R DL Read and Write Compatible
•Windows 7 Compatible
Product broucher
LinkIt does not support light scribe but the GH24LS50 models do.
Thank you for using
FixYa.
Hopefull this information helps.
I have an lg gh24 dvd/rw drive. After installing
this could be caused by a faulty eletrical connection/lead that attaches to your dvd rom all electric current and data must travel to and through every device in a computer for a computer to work properly to make sure its getting continuos current/voltage you could use a multimeter to check this
hope this helps
My dvd-r discs are not working on my lg dvd
It could be the disks themselves, try another brand or and the disks in a different computer and see if anything changes. I have gotten those cheap 25-50 dvd stacks on the cheap that have completely failed and ended up taking them back for replacements,
I purchased LG SATA DVD
> unable to read any CD or DVD. Its detected in device manager but cant ready media.
Can you hear it "spinning" the media? If not, you have a "defective" unit (motors or bearings).
If it spins, but nothing is read, then you have a "defective" unit (dead laser).
Take it back to where you bought it, and get them to test it, to prove that it is "bad", and then for them to replace it.
> in Hardware details it shows HL-DT-ST DVD RAM GH24NS50 SCSI CDROM Device.
Normal for most SATA devices.
> it shows as HT-DT-ST CD-RW GCE-8526B ATA device.
Perfectly normal.
I have an LG GH24NS50 DVD RW and I added another
make sure that the dvd-rw is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
also
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
only do the registry check if you cant see the drive/s in windows explorer/my computer
or it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. hope this helps
Lg super multi securdisc driver
Optical drives (at least all modern one's) do not require a driver when run in a Windows environment. The OS provides the support automatically. Is the drive shown/listed in My Computer?
Drivers needed
available here http://www.driverscape.com/download/hl-dt-st-dvdram-gh24ls50-ata-device
What normally burns out the LG Hi-Fi Amplifier?
Full 'make model (what it is)' in all questions please, first 3 words.
Capacitors can split or bulge, resistors can burn,, the transformer can fail internally..
Take it for repair unless you have the thousands of dollars of test equipment and have do the 2 year electronic course.
What does 9 red flashes mean on LG multi V LMU540HV
A communication error has occurred between the outdoor and indoor units. Faulty wiring or a malfunctioning control unit may be responsible. Contact LG customer service for assistance. Their number is 1 800 243 0000.
