20 Most Recent
Lenovo ThinkPad T410 Core i5540M 253GHz4GB320GBDVD+RWabgnBTGNICFR141" WXGA+W7P (252225U) PC Notebook Questions & Answers
How do i unlock 4338 docking station, laptop will
hello mr, Matt the hyjacker?why not ask using all your facts, and not OPsmy wild guess is the OP inserted to the docking stationand bent pins, and now will not work.the word unlock here is poor choice of wordsas many docking stations have option key mech. KEY lock.so if NOT a key lock !then it is just mechanically jammedwhy not get someone to fix itor try to unjam it your self , I am sure the OP did 8 long years ago.or sold it or scrapped it.invert the whole thing, LT and dock.upside down, now press dock firmly the LT bottomnear the Connector end and at same time...then unlatch the dock using the dock latch release now. this relieves pressure (gravity) and can aid in the cure.
Dimm display
Hi Sandeep,
The screen displays is dim because there is no backlight.
There
are two parts responsible for lighting the display. First is the CCFL
(Cold Cathode Florecent Lamp), which is the back light and the second
is the Inverter board, which provides high voltage to the CCFL. Either
of the parts can be faulty or in some rare cases both. But most likely
it is the CCFL (Lamp). Its life is limited and depending upon how long
it has been in use, you can have a better idea - if its the CCFL or
Inverter.
So, my advice is that you get it properly checked by any professional for replacement of CCFL.
Hope this answers your question!
Good Luck!
Don't forget to convey your feedback
CreativeTECH
Hai,i had a bsnl3g mobile, when ever i attempted
CONFIGURE BLUETOOTH WITH COMPUTER
Hi friends
It s a simply way, to solve the problem.you will follow the instruction.
Follow the bellow step.
1. just enter your Bluetooth in your pc.
2. when the icon show your task menu bar just
3. double click on icon
4. add>check on my device >next(ensure phone Turn BT on )
http://www.acroname.com/garcia/tutorials/bluetooth/connection/connection.html
you can see the phone model which Bluetooth on.
just select the device >choice any ask code >I will advice you, please select, let me choice> type any 8 digit >next >now the same
number > in your mobile >finish
For dial up go r click on my network>properties>create a new connection> connect to internet>next >set up manually>connect
using dialup>select your mobile modem>next >type any name >type the exact name and number eg: for Airtel=*99#>next >no user
name and password just next >check on add short cut>and finish.
Just double click on the icon, it will connect soon.
Or
you can install PC suit and set it through the following step.
Setting> Setting >participate tic on yes .Double click on phone icon >next>tic on Bluetooth connection >next >select yes the phone
mobile>next
Remember always set the mobile for connection select the yes.
Hope it will help you.
SL500 does nothing when power
remove the battery large.
then run on AC pack only
#1 top failure of all mobile PC is that battery, so unplug it
then test with AC pack only.
work now.? and all vents must be clean, end to end. not just fan.
there i no fuse it uses current regulator, imagine genius magic electronics fuses that never blow out, and bingo.
OK big battery out, an RTC coin cell fresh.
then fan blows.
next is BIOS, do the BIOS screens work if not the mobo is dead.
have 2 RAM stick on the 2 slots>? try one at a time
run the PC with all modules removed, (options)
remove hdd?
remove, dvd drive.
think like this. Get bios working first
learn that modules can short, and when they do the power regs shut down.
so we unplug all things to the mob,
until only 1 ram and cpu remains.
see? (this is called power overload fault isolation tactics)
even the screen only can be dead, you never mention text showing
you can test the mobo with external screen via that rear (?)_ VGA jack what if that worked, did you learn something here, sure.
this pc has tons of modules to pull, even bluetooth. wifi, sound and more. if you look at all parts inside or sold by ebay, bingo. lots
Screen lock
It helps to know what device model and OS you are using though the following steps for changing from pattern lock to slide are for Android OS 4.0 (Ice Cream Sandwich):1. Unlock your Android device2. Find the Applications menu and select "Settings"3. Under the "PERSONAL" group, select " Security"4. Under "SCREEN SECURITY" group, select "Screen Lock"This will ask for the security pattern first.5. The options for screen lock will appear, select "Slide" and you are done!Hope this helps.
G500 how reach bios setting
Just press "delete" "F2" or "Escape" keys imediately then you power on your computer. (Key depends on your pc model)
