20 Most Recent
Acer Aspire 55345410 Notebook Questions & Answers
It says that the acer
I am glad to HELP YOU!
Go START > ALL PROGRAMS > ACER CRYSTAL EYE WEBCAM and select it. Click on ACER CRYSTAL EYE WEBCAM and that should activate the webcam.
Once the webcam is active you will see an icon displayed in the TASKBAR.
Anyway, using any communication/chat/social software like Yahoo!Messenger or Skype or whatever that requires a webcam connection it will open automatically once the video conversation is on.
GOOD LUCK!
... and don't forget to RATE, please...
My cursur is not moving,how do i fix it
Does the mouse pointer move? Does the mouse work? Does the Keyboard work?The cursor moves on keystrokes from the keyboard or from taking the mouse and pointing it and clicking in a text area. make sure you have not turned the touchpad off. Some laptops will have a button that is located in the middle of the touchpad at the top of the touchpad that toggles the mouse pointer on and off. Some laptops will have a set of keystrokes that toggles the touchpad on or off. Normally you will have to Press and Hold either the Alt or FN key then hit the corresponding key that controls the touchpad. Most times the correct key to hit will have the icon of a finger pointing at a square box that represents the touchpad.You may have been hijacked by a virus or infection. Boot up in Safe Mode and see if it works.Go to www.google.com and in the search box type:"Download cnet Malwarebytes" (without the quotes). Download andinstall malwarebytes from the sites download.cnet/malwarebytes. When thesite opens up click on the Green Download button on the left. Do notclick the Red Download button, that's junk. When it finishes installing the GuiInterface will open up with an offer to Accept a Trial Version orDecline. CLICK DECLINE you want the totally free version. Run aQUICK SCAN. As it scans, if it finds infections the number will be inred. When it finishes scanning, click SHOW RESULTS. A notepad textdocument will open up showing you the results. You can close the textdocument and go back to the Gui Interface where you will click REMOVE SELECTEDRESULTS. The objects will already be selected for you. When itfinishes removing the objects click ok and it will sometimes reboot yourmachine.
ACer Screen is pitch black, but system runs
Check if this will work on an external monitor, if it will, you can point the finger at the following:
- Inverter failed: If you cannot see any image on the screen even a faint one, replace the inverter
- Backlight gone: if you see a faint image on the screen, the screen needs replacing
- Possible failure (unlikely) of the vga cable
If it will NOT work on an external monitor, the graphics chip on the motherboard has failed.
Why won't my touchpad work
YOu can open control panel- back up /restore to set the PC to an earlier set date. Now the programs will be reset . Also try and reinstall the drivers of the PC. if this wont solve there can problems in the hardware. Slightly warm the pads to make sure there is no moisture.
My pc is requesting the product key in order to
I have MOW10 ( Microsoft office word 10), but anyway. If you have bought a computer which comes with word 2007 then you have to buy word 2007 separately. Once you have bought it, it should come in a disc and a product key which you need to submit within a certain amount of time.
PCHELPSTER007 from youtube
I have never used word on my laptop and now need
Sadly Acer units come with only a trial version of Microsoft Office pre installed,that lasts for 60Days only, your office might be out of date. or you can also contact microsoft about that. 0860225567
