20 Most Recent
Gateway LT2030u Netbook Questions & Answers
I have a lt2030u gateway netbook I need a ribbon
Jason,
AMAZON no hits.
A eBay check for:
lt2030u gateway display ribbon cable (and)
lt2030u gateway LCD ribbon cable NO HITS!
Then I tried hunting for:GATEWAY LT2016U LT2022U LT2030U LAPTOP LCD REPLACEMENT SCREENS and found this part number for the SCREEN: Gateway F846431 hoping to track down a supplier?
NO HITS there either!
My final recommendation? Go to eBay and look for Auctions:
352215358996
122852779509
Now go to the bottom and
"Ask buyers and sellers about this product"... MESSAGE the guy OR ~
CALL him at:
(201) 830-1637
between
11:00 Am - 6:00 Pm ET
Monday through Friday (excl holidays)
MAYBE they have your cable?
Anthony
GATEWAY LT2016U LT2022U LT2030U LAPTOP LCD REPLACEMENT SCREEN 10 1 WSVGA...
Factory reset LT4010u gateway netbook
You press the F11 key at start up and you should be presented with the Gateway System Recovery option. That will allow you to
restore your computer to it's originally installed state.
If this is because of a bios password...
Please contact Gateway, I do not assist in helping to bypass
security features.
How can i reset my Gateway Netbook?
Hold down ALT Gr or Alt Car and tap the F10 when the system turns on , you will get recovery console , select restore system to factory defaults ,
if system is booting into windows go to
Start Menu - All Programs- Gateway - Recovery manager - restore - restore system to factory defaults ,
this will wipe all the documents , pictures everything in the system
Gateway lt20
get a external cdrom drive and have the bios boot from there
Where is reset button
None.
remove battery and power cord. Wait for 10 minutes. Plug in only power code from AC Adapter.
Gateway window recovery
Forgot your Windows Vista password? Don't worry - it happens to a lot of people.Vista and Windows 7 allow you to create a password reset disk.If you installed Windows XP, boot up Windows XP in Safe Mode and log on with the built-in administrator account.Besides,using
Windows Password Reset ,it is easy and safe ,and support all systems.
My screen on my gateway
If your comfortable opening up the laptop, and either have done it before, or know someone who has and is willing to help you, yes you can replace the LCD screen in the netbook. If not, your best solution would be to take it to a technician or repair shop, or, if financially viable, buy a new one, and swap out the harddrives to that your new machine has all of the information of the old one on it.
My gateway lt2016u netbook fell
You will need a razor blade.
Where the black flat part of your screen meets the silver outlining there is a crease. Take the razor blade and slide it through the **** all the way around the screen. You might need to pull up on the black flat part with the razor blade to get it to unsnap. Then inside you will see the screen and a bunck of screws. Unscrew all the BLACK screws. Then pull the scrren forward. It will be screwed in on a metal rod on both sides. On the side of the metal rods will be some screws. Unscrew theses screws, then the screen will come out. You are not finished yet. The screen will be hook up to a a chord in on its back. Unplug the end that is hooked directly into the screen. You may need to take some tape off in the process. Then do the reverse steps with a new screen.
I went to restore my
1. You may have a bad power supply adapter. It may not have recharged the battery
2. Contact the manufacturer and see if you can get a replacement power supply.
There are some power supply adapters on Ebay for some models. check there it may be cheaper. I purchased several for my Dell and they are very well put together and I had them for almost 2 years no problems.
