20 Most Recent Dell Studio XPS 8000 (DXCWKW12) PC Desktop Questions & Answers
Bottom drive won't open dell xps 8000
Click on the COMPUTER icon that shows the drives and right click on that drive and select EJECT. If it wont open, look for the pin hole in the front and use a straight paper clip to push straight in and see if it opens.
9/16/2015 2:07:12 AM • Dell Studio XPS... • Answered on Sep 16, 2015
Dell cd drive door won't open
CD/DVD Drive Tray problems There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work. Go to My Computer and right click on the drive and click on Eject. If this does not work then you can manually open the CD/DVD drive tray by - Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc. If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
2/22/2013 10:24:39 AM • Dell Studio XPS... • Answered on Feb 22, 2013
"operation system not fount" after pressing the start button
Turn it off. Symptoms suggest hard drive failure. Use of s taking a physical battering. This may damage data beyond recovery. The drive Take it to a shop. Your other choice: Oddly, freezing the hard drive sometimess temporaily fixes the drive long enough to recover data. Replacement of the hard drive is the likely fix. Unless you want to try to freeze the HD and copy data off of it quickly, only a shop specializing in data recovery might recover such. Hopefully youhave backed up data to another drive. You might want to consider a new laptop, after you eye the possible cost of repair and/or data recovery.
6/3/2017 8:35:46 PM • Dell Studio... • Answered on Jun 03, 2017
Studio XPS 9100 - I cannot access the internet from this computer consistently and shutting down takes 25 minutes
Always include the version of Windows in your posts. Could have been a RAM problem if you got 4 beeps and you seem to have resolved that by reseating the modules. But the RAM error may have caused some corruption to a file on the hard drive. Assuming the diagnostics pass, you can reboot and press F8 before Windows starts to load. Select Last Known Good. If that gets you to the desktop without errors, shut down normally and reboot normally, and you should be good to go. You may also want to run chkdsk on the hard drive: Click: Start>run Type in: chkdsk C: Click OK Accept the offer to run chkdsk at next boot and then reboot. chkdsk will run before Windows loads. It may take a long time, depending on size of your hard drive, so be patient.
12/27/2016 11:43:50 AM • Dell Studio... • Answered on Dec 27, 2016
2answers
Rapid beeping
Can you specify WHEN and perhaps what was on the screen? What were you doing when the problem started?
12/30/2015 7:11:59 AM • Dell Studio... • Answered on Dec 30, 2015
Bettery required replacement which in not available in Delhi storeor nearby?
Hi Praveen, My name is Pradeep and I work for Dell's Social Media Team. Please reach out to our Sales team at 1800-425-4026 or 080-25108032 to purchase Studio laptop Battery. Pradeep Lokesh Social Media and Community Professional Order Status: http://del.ly/61822hij Download Drivers: http://del.ly/61832hid
6/29/2015 8:29:56 AM • Dell Studio... • Answered on Jun 29, 2015
Sometimes a story or video stops and an upside !shows up like it is being censored?
Hi Ken, My name is Pradeep and I work for Dell's Social Media Team. Please follow the steps in this link: http://bit.ly/1LfQ23w Right click on your Desktop and select the Screen resolution option, uncheck the Allow the screen to auto-rotate checkbox. Let us know the results. Pradeep Lokesh Social Media and Community Professional Order Status: http://del.ly/61822hij Download Drivers: http://del.ly/61832hid
6/17/2015 4:13:46 AM • Dell Studio... • Answered on Jun 17, 2015
Can I charge my PP39L laptop with a USB cable?
the only thing to be aware of is the voltage cannot exceed that required for the laptop . for example if the solar panel puts out 12 volts you will need an adaptor before the usb connection to reduce the power to the voltage for the laptop
3/29/2015 4:37:46 AM • Dell Studio... • Answered on Mar 29, 2015
Kidspace portal login page
go to Dell.com and contact Support I’m happy to help further over the phone at https://www.6ya.com/expert/wynn_5ba0205233ebfc15
1/25/2015 12:53:00 PM • Dell Studio... • Answered on Jan 25, 2015
When I push the on button on my laptop 1749, it won't stay on until I push it multipule times.n
either the spring inside is broken or it needs cleaning up
1/5/2015 3:34:25 AM • Dell Studio... • Answered on Jan 05, 2015
Dell laptop has displayed "There is no disk in the drive. Please insert a disk into \Device\Harddisk1\DR2."
Press CTRL+ALT+DELETE, select "start Windows Task Manager" Under Applications Tab, right click on the program you want to close. Select "Go to Processes" Right click on the highlighted process and select"End Process Tree"
1/5/2015 3:23:36 AM • Dell Studio... • Answered on Jan 05, 2015
Device cannot start code 10
Generally, a code 10 says that the driver was not loaded, which could be the driver is missing or corrupted . Go to the Dell download center and download the driver for your profire device. It could be on a driver CD that came with the computer Too
12/14/2014 2:08:59 PM • Dell Studio... • Answered on Dec 14, 2014
Hi my 17" dell laptop model no:pp31l has stopped working it just says bootmgr is missing
This could be due to a CD or DVD left inside the DVD drive. The laptop may be trying to boot from that instead of the hard disk. Make sure no USB flash drives or CD/DVDs are left connected/inserted. If the laptop is trying to boot from the hard disk then the files on the hard disk may be corrupted. This is hard to correct without risking loss of your data. Try running the diagnostics by pressing the 'Fn' key (keep it pressed) and press the power button to turn the laptop on. You should be able to access the diagnostics from there.
11/13/2014 8:12:11 AM • Dell Studio... • Answered on Nov 13, 2014
Laptop won't turn on when I hold down the power button
Check the power source, power switch on board, power button on laptop.
10/22/2014 9:47:56 AM • Dell Studio... • Answered on Oct 22, 2014
HOW TO GET A CD OUT OF STUDIO 1735 WITH A SLOT
there is a button on the F keys, the top row, it looks like a triagle on top of a line press it and it should eject the disk, if this does not work or you cant find it, go to My Computer and when you see the icon of the disk, right click and click eject on the menu.
9/4/2014 5:22:23 AM • Dell Studio... • Answered on Sep 04, 2014
Why wont picasa open?
Uninstall your previous picassa and then reinstall it again.
8/10/2014 10:06:22 AM • Dell Studio... • Answered on Aug 10, 2014
How to format my Dell computer
Your drive may be toast. You need to find the right F key (typically F2 or F8 or F12) to open the BIOS menu. Start pounding on one while booting until you find it. You may have to try all 12 F keys. Once you get the BIOS menu (not the boot menu), there should be a device section. Make sure your C: drive is visible to the BIOS. If not, the drive is usually bad and needs replaced. You will need a drive preloaded with WIndows, or you will also need the Dell recovery CD set. However, if the C: drive looks OK, next find the right F key to open the boot menu. There should be options there to boot Windows, Safe Mode, Restore to a previous check point, or recover to factory settings. If this does not work, you will need to get the Recovery CD set from Dell for your model. Be warned this usually destroys all old data files.
7/26/2014 8:21:14 AM • Dell Studio... • Answered on Jul 26, 2014
Flashing 1 white 3 orange
Hi Royce, You need to replace your laptop battery - its dead. To prove this, take the battery off and just plug the mains charger in. The light should stay solid white. Many thanks, Jon.
7/2/2014 10:00:59 PM • Dell Studio... • Answered on Jul 02, 2014
Dell Studio XPS 8000 (DXCWKW12) PC Desktop Logo
2 questions posted
Popular Products
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
Studio Dell
  • Studio Dell
Most Popular Question
bottom drive open dell xps 8000
  • Computers & Internet
