20 Most Recent
Ricoh Aficio SP C231SF Color All-In-One Laser Printer Questions & Answers
Color not registering
Try going into the diagnostics of the printer.
Either in the menu, or network connection.
Try running a clean process if this has one.
How long had your toner run out for.
Try pulling all toners out, then see if you can pull out the spool drum (printing drum)
check that they are all clear.
Are you using original toners, or remanufactured ?
Also check if you have an excess toner cup.
This may be full and require either emptying or replacing.
I can not install my
There can be multiple causes why you can't do it but 2 are the most common:
1 - you don't have the admin rights to do it - in that case right click on the installer and select Run As, then input the password of the admin account.
2 - the installer for the driver that you try to use isn't the one for your particular operating system - in that case go here
http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/spc231/spc231en.htm
select your OS and download (as in Save, not Run) the correct installers for all the necessary drivers. Once the download is complete close the browser and launch the installers one by one.
