20 Most Recent
HP Designjet T1200 Large Format Color Inkjet 44 549 ft h Color 2400 x 1200 USB Plotter Printer Questions & Answers
Error 59.2:00 in hp designjet T1200 i replaced
First time are you opened this printer? or else some one attempted? This error indicating that re-used or un supported parts are installed..My suggestion replace with old parts check the error message..then do the trouble shoot. Error 06:00 replace formatter or Hard disc..replace one by one & do the diagnostic test then confirm the part condition, replace the defective part/parts ..But replace with new parts only..
Hp t 1200 plotter
erroor
Media_Axis motor malfunctioning/shut down.
Reconnect the drive motor connections. Perform the paper drive diagnostic,check media advance drive, replace PCA,,
Printing to HP Designjet T1200 from Linux, RHEL
This can happen due to the firmware on the plotter, even if it happens only with some postscript files.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=3980523&prodTypeId=18972&objectID=c02189041
Error 79:04 HP 650T
79 errors are usually bad firmware that needs replaced or updated. Sometimes it is simply a bad print job being sent. Check to see if only one print job is causing this error, or if it happens with everything you try to print.
How do I bypass the expired cartridge on a HP DesignJet T610?
The dates are on the package for a reason. The ink dries out or changes viscosity over time and will likely clog the printhead.
My advice is not to stock up on cartridges because of this problem.
If you look online, you can find replacement chips or instructions on how to reset the chip on the cartridge.
How to change ip address on hp 5500ps
There are three ways of configuring IP address on any HP Printer:
A.- Using the control panel
B.- Using the web server
C.- Using the Jet Admin Utility
We'll deal with the contro panel setup.
To access the contro panel menus
1. Press OK (Check Mark) button once to access MENUS.
2. Press Up Arrow or Down Arrow buttons to navigate the listings.
3. Press OK (Check Mark) button to select the appropriate option.
4. Press Return to return to the previous level.
5. Press OK (Check Mark) button to exit the menus
So to configure IP address:
Press Check Mark
Navigate to the CONFIGURE DEVICE Menu using Down Arrow (the menu scrolls, so you may use any combination of Up/Down arrows)
Navigate to the I/O Menu
Navigate to the EIO 1 menu
Navigate to TCP/IP
Navigate to BootP entry
Press Check to disable it (Off)
Press return
Navigate to IP Address, press Check
Use Up/Down buttons to change the address, check to move between octets.
When finished, press Return
In the same way, enter Mask and Default Gateway
Press Return until you are out of the Menus.
Done
