20 Most Recent
Lexmark X5650 AllInOne InkJet Printer Questions & Answers
My lexmark 5650 wont connect to my computer
A quick fix for most communication errors can be achieved by
resetting the printer and/or rebooting the PC. Simply disconnect the printer
from your computer (if USB connected)> reboot your pc > unplug and
re-plug the printer into the power source to reset it. When the printer turns
on, reconnect it to your computer (if USB connected). Then try to print again
once the computer fully recognizes the USB connection or when the WiFi light on
the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
- Disconnect the USB cable
connecting the printer from your computer.
- On your computer, go to Control
Panel > Printers and Faxes.
- Delete the Lexmark print
object.
- Reboot computer.
- Re-brick your printer by
pulling out the power supply - black box where the power cord is plugged
into on the back of the printer, and re-plug after 30 seconds.
- When the printer turns on,
reconnect it to the computer.
- Wait until your computer fully
recognizes the USB connection. To check, go to Control Panel > Printers
and Faxes. If you see a new Lexmark print object in the list, try to print
a document to verify that the problem is fixed.
You may also try to update your printer driver
by visiting the Lexmark website at http://bit.ly/eVzv1x. Select your operating system, download and
execute the file.
Printer stuck on spooling
Try the steps below to fix the spooling problem:
- Browse to Start -> Run...
and type in NET STOP SPOOLER (this will stop the print
spooler service)
- Browse to your windows\system32\spool\PRINTERS\
folder. You should see files there ending in .SPL and .SHD created around
the time you tried to print - delete these files.
and type in NET START SPOOLER (this will restart the
print spooler service)
Try
to print a document again to verify that the problem is fixed.
CARTRIDGE ERROR
The
problem could be due to a communication failure between one of the printheads
(cartridges) and the All-In One (AIO) or by a short in one if the printheads. Please follow the steps
below to identify and fix cartridge issues:
- Make sure the printer is on.
- Open the printer cover. The
print cartridge carrier moves and stops at the loading position, unless
the All-In-One is busy. Note: If the carrier does not automatically move
to the center, turn off the printer or unplug the printer from the power
source and then carefully slide the carrier to the center.
- Remove both cartridges from the
carrier.
- Close the printer cover.
pulling out the power supply - black box behind the printer where the
power cord is plugged in to, and re-plug after 30 seconds.
- When the printer turns on, reinsert
one cartridge first. Close the printer cover and check for any errors.
- If no error appears, reinsert
the other cartridge. Close the printer cover.
- Replace whichever cartridge is
causing the error to appear with a new genuine Lexmark cartridge. Try to
Printer Problems
object.
- Reboot computer.
Paper wont feed
Leading cause of paper
jams is debris / foreign objects that accidentally fell into the paper feed
area. Please try this approach to fix the problem:
- Remove the sheets of paper from
the feeder.
- Grab a flashlight and look
inside the feeder for any debris or foreign objects.
- If you're willing and
physically able, you may also carefully turn the printer over. Any debris
should just freely roll out from the feeder.
- If feeder is clear, place the
printer on the table. Open the printer cover and remove the cartridges.
- Check the cartridge area for
any obstructions in the paper path.
pulling out the power supply - the black box where the power cord is
plugged into. Re-plug after 30 seconds.
reinsert the cartridges and load some paper. Try to print again to verify
I just bought ink cartridge and says ink low on my lexmark x5650 so i just bought ink cartridges for my hp 4140 and it wont work, is this a cproblem with my computer and not my printers? 2 printers do
As far as the Lexmark printer is concerned, try the steps below:
The
carrier.
reinsert one cartridge first. Close the printer cover and check for any
errors.
