20 Most Recent HP Officejet 6500 AllInOne InkJet Printer Questions & Answers
On HP 6500 printers, remove screen and try heating the connection elemants with hair dryer or something similar. Nothing to hot. The led bars should restore. Here's a link on how to remove HP 6500. Do same for 6500A model, but screen is a bit different, so check out the other video for HP 6500A and 6500A plus printers:
HP 6500:
HP Officejet... | Answered on Jan 30, 2019
Try soaking printhead in the cleaning solution and it will resolve the issue. Check out the video on how to repmve printhead below. Put it in about half inch of solution which is 50% water, 40% window clening solution like windex, and some ammonia or rubbing alcohol.
If you have Windows 7 you can check this by clicking on the "Start" button at the bottom of the screen, click on the "HP" folder and click on "HP Solutions Center". A graft will come up showing you the printer cartridges levels. Click on the small graft chart at the top right of the screen and the graft will enlage and show you exactly the staus of the ink levels. Click "Print" at the bottom of the screen and it'll run a print test. All 4 cartridges need to be above the "Low" level. It only takes one of them to mess up the print.
HP Officejet... | Answered on Mar 08, 2018
Hi. To reset an HP Officejet 6500 E709a or 6500 Wireless E709n, follow these simple steps:
1. Press the (*) and (#) buttons on the printer control panel at the same time and let go.
2. Use right and left arrows to scroll trhough menu and select "Resets"
3. Select "Semi-Full" reset and printer will shut off in a few seconds.
4. Unplug the printer from wall and wait 30 seconds.
5. Plug in the printer, Turn printer on and selec basic settings.
Your printer is now reset!!!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
HP Officejet... | Answered on May 27, 2017
Does this happen with anything else you try to print, or is this the only thing that doesn't print correctly?
If this is the only thing, then it's not your printer.
Try downloading the statement and then printing it. You'll need Adobe Reader.
HP Officejet... | Answered on Sep 03, 2016
You have to change print size by choosing a larger font in the software you used to produce the document.
HP Officejet... | Answered on Aug 11, 2016
I would suggest using the printers own head cleaning programme
HP Officejet... | Answered on Mar 05, 2016
if there is paper take it out and put it back in and move around anything that move even a little bit, it sounds like something didn't connect, if it works ok don't worry about it.
HP Officejet... | Answered on Jul 31, 2014
cartridges have chips, you need a cartridge with a special chip that resets each time. These can be bought on ebay or amazon. You cant refill factory cartridges with oem chips.
HP Officejet... | Answered on May 28, 2014
I wonder whether the Word Doc SDK I am testing these days can help with the related programs?
How to Get Started with VB NET Word
HP Officejet... | Answered on May 04, 2014
I would listen to the response to Geraldine Watts by Handyman
back in 2007. Not printing sounds like dirty heads that can be
lightly wiped by just a water damped qtip. This helped me at one
time. Black vertical lines are fixed by pulling plugs for a couple of
minutes (resets machine). It could also be a bad cartridge but I
doubt it. I would never waste money on buying parts because
the new printers to purchase are cheap enough.
My 6500 broke when I pulled out several pieces of paper and then got an ink failure error. No fix for this. I then bought the 7520.
photosmart and I am glad my 6500 broke.
I bought direct this time from HP at $149 (hp matched a best buy sale) as well as buying their warranty for $34 that covers next day replacement and any phone questions I might have for 3 years.
I love hp photosmarts only because they are the 'king' on photo
quality but I hate the reps charging if you are out of warranty.
If HP offered help to those out of warranty they would then have no
competition in the printer world. I buy my inks from local stores like staples. Good luck with your machine.
HP Officejet... | Answered on Apr 08, 2014
Try reset the printer after you have cleaned the printheads. http://www.youtube.com/watch?v=31TbWMrTaFk
HP Officejet... | Answered on Oct 05, 2013
Not sure exactlly what you mean but you may want to check the ink and the printer heads by doing the following checks:
More than likely your running out of ink. Check the ink levels first.
If you've got plenty of ink try cleaning the printer head by:
Click "Setup" (just below and left of the LED screen) on the printer.
Scroll the Led screen to "6. Tools". Hit "OK"
Now scroll to "2. Clean printhead". Hit "OK".
This should do it..
HP Officejet... | Answered on May 24, 2013
Try connect the printer to different wall outlet.
Regards,
Sean
HP Officejet... | Answered on Apr 22, 2013
CARTRIDGE IS ABOUT TO RUN OUT
HP Officejet... | Answered on Feb 26, 2013
HP Officejet 6500 AllInOne InkJet Printer Logo
Popular Tags
96 questions posted
Clive
Clive
Thomas F. Schneider
View Most Popular
OfficeJet HP
  • OfficeJet HP
Most Popular Question
not printing entire page approximately
  • Office Equipment & Supplies
