20 Most Recent
Brother MFC9440cn AllInOne Laser Printer Questions & Answers
Brother MFC 9440 won't recognize new toner cartridge
I knew it needed to be reset to recognize the new toner. Glad you found the info in the electronic menu. Thanks for using Fixya. If my suggestion was helpful could you please rate it for Fixya. Thanks
2/13/2014 4:59:15 PM •
Brother...
Answered
on Feb 13, 2014
My printer in printing crooked when i print a lot
first determine if its the paper feed by printing several copies off the glass not using the document feeder. If they are crooked coming from there check the paper cassette and make sure the side quides are snug against the stack. That is the usual problem.
2/15/2011 1:49:41 AM •
Brother...
Answered
on Feb 15, 2011
Have lost driver installation cd
If you have lost the installation CD, you can download the installation driver and software from manufacturer's website by clicking this
link
On the page which opens:
- Select the operating system of your computer (Windows Xp/ Vista..) from the drop-down list
- Select the Language (English) and click the Search button
- Download and install the drivers and software from the next page which opens.
Hope this solves your problem. Thanks for using FixYa.
8/27/2010 6:36:51 AM •
Brother...
Answered
on Aug 27, 2010
Brother MFC scanner bar is stuck
check the continuty in scanner cable to cis unit and check the continuity 2ends off scanner cable.
1.cable problem
2cis problem
Cannot reset toner counter for Brother MFC-9140CDN printer
You can reset the toner cartridges via the printer's menu.
- if an error message appears on the LCD display, press the Cancel (X) button to show the main menu.
- Press the Fax button to make the numeric keypad visible. Then, locate and only locate the Asterisk (Star) button on the numeric keypad. It is important to remember its location as it will not be lit up later when needed.
- Press the Home button to return to the main menu.
- Open the front cover of the printer (to access cartridges).
- With the front cover open, press and hold the unlit Asterisk (Star) button for 5 seconds.
- The reset menu will now appear on the LCD display.
- Scroll through the menu to select a color and yield to reset.
- The LCD will read "Accepted" once the reset is complete.
http://www.zinetic.co.uk/brother_mfc_9140cdn_toner_refill_kit-news.aspx
Scan unable af
The scanner unit is faulty or the flat harness was not fitted properly to the main board.
How do I print envelopes on Brother MFC6490CW
Load the envelopes in like paper, tell the printer the size of these to set the paper size, then whatever you're using to print on the envelopes, set up the page size the same size as the envelopes. You should then be able to print on envelopes
