20 Most Recent
Motorola MC55 Handheld Mobile Computer PN MC5590PY0DUQQA9WR Portable Terminal Questions & Answers
Where is the Motorola mc55 wireless mac address
Surely you already found the answer by now but if not: Click on the MS start icon (lower left corner of the main screen), on the Start page look for the "Wireless Companion" folder then look for Wireless Status icon and click on it. You will see a list of 8 options; select option #3, IPv4 Status; the MAC address is located at the bottom of the page.
Motorola mc55 wifi problem
Hi Chris, Pls check in wireless settings>> security settings.Whether any MAC authentication is enable with the AP (Access Point).If yes, kindly add the MAC address of your device which you want to connect to the AP.
The MC 3300 scanner is frozen on a white background that has a blue motorola symbol. and says MC33X series
If your MC3300 scanner is frozen on a white background with a blue Motorola symbol and says MC33X series, you can try a soft reset to see if that resolves the issue. To do this, follow these steps:
- Hold down the power button until the scanner turns off.
- Wait a few seconds, then press the power button again to turn the scanner back on.
If the scanner is still frozen after attempting a soft reset, you may need to perform a factory reset. Please note that performing a factory reset will erase all data on the device and return it to its default settings. To perform a factory reset on the MC3300 scanner, follow these steps:
- Press and hold the power button and the volume down button simultaneously.
- Keep holding both buttons until the scanner vibrates and the Motorola logo appears.
- Release both buttons.
- Use the volume buttons to navigate to the "Factory Reset" option, and then press the power button to select it.
- Confirm that you want to perform a factory reset by selecting "Yes" using the volume buttons and pressing the power button to confirm.
- Wait for the scanner to reset and restart. This may take a few minutes.
If a factory reset does not resolve the issue, you may need to contact Motorola's customer support for further assistance.
2/24/2023 9:51:25 PM •
Motorola...
Answered
on Feb 24, 2023
