20 Most Recent
Hyundai W240 Monitor Questions & Answers
Hi, I have a problem with a Hyundai W240 monitor.
Hi Mjau_beibi,
Technically, yes. It requires a level of expertise though. You would want to start by replacing the pixel panel. (Which is inside of the monitor and requires knowledge of monitor repair) - I would not recommend doing it yourself unless you are familiar with in-depth repair of components like this. Depending on the cost of the repair, it may be worth it to purchase a new monitor unfortunately. Sorry for the relatively bad news. Hope all works out! - Cheers!
Thanks for responding...is there anyway
Well, in most cases, the only location where something can be loose where a user is involved, is the cable connection to the VGA or DVI card and/or to the monitor.
Make sure the pins are not bent.
There are no user serviceable parts on the monitor, in general.
Service should be sought out at an authorized Hyundai service center.
If within the warranty period, then you may be able to get it repaired or replaced for free.
If not, there will be a charge for the service, if the unit is even serviceable after a certain period of time
outlined by the service center.
Good luck on this .
On a 2009 Hyundai 1.6 on the chains how many links separated the 2 cams
are you sure that it is a 1.6 motor
as 1.6 motors use a belt not a chain
your statement that it has 12 on each cam indicates that it is a v engine or a double over head engine
in any case you do not count links but put the colored links directly over the sprocket dots
you have to use a cam locking tool to get it right
8/3/2018 12:28:43 AM •
Hyundai...
Answered
on Aug 03, 2018
