20 Most Recent
4103LX Remote Start System with Two 4Button Remote Questions & Answers
I have a Dodge Caravan 2001 SE. Had the Avital
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u.. U get free manuals
I recently had an avital 4103 remote start system
As an L1 ASE Master tech I ALWAYS advise against aftermarket alarm systems, however the problem you are experiencing is due to an action that is not being taken by the vehicles control modules. The installer should tie into the door control modules or find out why the body control module is recognizing the command for the locking/un-locking action, (hence the lighting response), but the doors are not taking appropriate action. I would have to look at live data in the vehicles control modules to see what modules are being commanded to do what. Take it back to the place where it was put in and tell them to fix it or refund it.
Car rolls over with remote but will not start
Everything depends on missing information...like was it professionally installed?...and whats the year make and model of the vehicle. Here is some helpfull information.
go to WWW.the12volt.com then click menu tab
Choose vehicle wiring database
Choose your vehicle
Make sure all wiring was correct and any relays moduals resistor or any components required where used
If everything is correct than its your alarm and its faulty
How do I activate the alarm on my Dodge
The 4103 is not an alarm. It's a remote starter with keyless entry! Do you want the horn to sound when locking and unlocking? First, make sure that the horn wire was connected. Press and hold the lock button on the remote. That should activate the panic/car finder. The horn will begin to sound. Press and release the lock button to turn it off.If the horn is connected and, you want said horn to sound when locking and unlocking, open door, turn ignition on then off, press and hold programming switch until the horn chirps once. Release programming button, press and release programming one time then, press and hold programming button. While holding the programming button press and release unlock button on remote. You should hear two chirps from the unit. Release programming button, turn ignition on to exit programming, Test system.
Windshield wipers will not turn off.
Wow...I would return to the place where the installation was done. It's possible that the installer either tapped into the wire or, left the wire exposed after testing it.
No lights with avital
If your vehicle parking lights are working at the switch then, the inline parking light fuse(15 amp) of the Avital unit may be blown.
