20 Most Recent
Alarm Remote Casecover Accord Odyssey 02 03 04 Questions & Answers
Honda keyfob reset
Ingition switch on -> press lock
Ingition switch off -> on -> press lock
As fast as u can on the fifth cycle the car will lock
program is complete
Car wont start dont turn doesnt make any noise
this is called, NO CRANK.
no engine can start if it can not crank.
(exception M/T tranny push started in 2nd gear)
what year, (exactly)
is the immobilizer happy? (dash light for same tells you)
no crank are:
1: dead /bad or discharged battery (or main lugs rusty (corroded)
2: bad starter.
3: bad key line
jump start car, with jumper cables. or try a fresh charged battery.
if that fails , hot wire the starter solenoid, (it will crank and not start, key in pocket , hand brake set and wheels chocked)
no crank, now ? bad starter
yes crank now,, bad key line.
the above steps find the fault or lead you the pesky key line.
hint1: wiggle tranny shifter as you crank, (key) or try starting in neutral.
hint2: hit side of a starter motor to wake it up.(can save a life)
buy a volt meter.
2003 Honda Accord v6 Lites ,flicker when turned on
Best thing is take it to a mechanic who can hook it up to a computer that can probably find where the power drain is. if you don't have the money for that? Not sure if this will answer your problem: But it sounds like you have a short draining the battery slowly. If it was my vehicle and without any professional help; I would connect an ohm meter to the battery and pull each fuse, "one at a time to see if the voltage increases. You have to remember any instrument that is running while you do this will have the same affect, like if the door is open and the interior lights are on. Probably not the best answer you will get from this site but shorts are hard to locate. Especially one that takes weeks to drain your battery - or - maybe it is really a sudden drain that just happens when you do a specific thing; like leaving a faulty phone charger in overnite?
Lightbulb replace hondaaccordradio1998
I got this free Pdf manual from reliable-store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the 20 times I fixed the chipper in these 4 yearsmust try this bitman and reliable-store. Both are good
Gx610 Honda v-twin small engine one side want fire
Hi, If you did the usual testing (comp,Carb cleaning, etc.) then I would go to the electronic ignition box if it has one. I've been fooled before. Checking for spark, wire off, or plug out, isn't the same as a plug under compression , Good luck.
