20 Most Recent
3300l 2way Lcd Security System Questions & Answers
My movement sensor will not activate when veh is rocked, but the internal movement sensors work on entering,
Hi there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything
someone on fixya recommended it to me and I thank him even today
They have full manuals and it's verrrrry cheap and mine
I got free in offers
3rd time I also had an issue with the file so the girl replaced it in 30 mins
there is one more but i don't remember its name it was 2 years back bitman something link this
Try it out brother
Does the avital 3300L support remote start?
for heavy machinery cars etc. luckily there are many websites
that can help you repair
for eg site like reliable-store is very active in this.. instant help, emails and all that's fantastic
tried and tested !
Mustang 1967 and where do i plug the yellow wire? Where can i get 12v in run and in crank position but not in off position
There is an open switched accesory fuse location on the fuse block. Yours may still be on the headlight switch if not visible on the firewall. Or you can attach to the radio 7 Amp fuse. You will not be able to get both run and start together on one wire under the dash. You will need to add a blocking diode to any wire that runs to the "I" terminal on the starter solenoid- this is to keep it from bypassing the ignition resistance wire to prolong point life which you would do if simply wiring straight to that terminal. You would need a silicon rectifier of suitable current carrying ability for the alarm, and then any wire you run out to that location "I" you would attach the banded end of the rectifier to that terminal.
How can put my Avital 7345L remote starter on vibrate instead of chirping?
To put your Avital 7345L remote starter on vibrate instead of chirping, you will need to follow these steps:
- Press and hold the "Valet" button on the remote starter until the parking lights flash twice. This will put the remote starter into valet mode.
- Press and hold the "Lock" button on the remote starter until the parking lights flash twice. This will turn off the chirping feature.
- Press and hold the "Unlock" button on the remote starter until the parking lights flash twice. This will turn on the vibrate feature.
- Press and hold the "Valet" button on the remote starter until the parking lights flash twice. This will exit valet mode and save your settings.
- Test the remote starter to make sure that it is vibrating instead of chirping.
Note: If you have difficulty following these steps or if you have any other issues with your Avital 7345L remote starter, it is recommended that you consult the user manual or contact the manufacturer for assistance.
How can I get instrction book for reprograming avital remote starter for rpn 7111l
If you are looking to sync the remote key fob to the remote starter:
Remote programming 1. Turn key to the ON position 2. Within 5 seconds, press and release Valet button one time. 3. Within 5 seconds, press and hold the Valet button. The LED will flash one time and the horn honks to confirm entry into remote programming. 4. Press the button on the remote control. 5. The horn honks to confirm the remote has been programmed. 6. Release the Valet button, and turn the key to the Off position. 7. The horn sounds one long honk to confirm that remote programming has been exited. The programming routine exits if any of the following occurs: • The ignition is turned off • There is no activity for 30 seconds • The Valet button is pressed too many times
