20 Most Recent
MicroBoards PF-2 InkJet Printer Questions & Answers
How do i clean the print heads
Get the manual here, and it will show you the clean function... http://www.manualslib.com/manual/103031/Microboards-Technology-Pf-2.html
How do i clean the heads
The printer may have a menu that
can guide you step by step or you
might try and see if your pc can help
you. Just go to printers and devices from
your start menu and then click on properties.
Look and see if there is an option for maintainance
Printer only prints up to five copies no matter
Hi
There is problem on printer driver. You need to set up again the printer by adding new printer and set it as default printer. When it finished the test page, then it solves your problem. Delete the old printer icon afterwards
I am attempting to install
Have you actually gone through the installation process? I understand what Virtual PC is supposed to do, but it may not be compatible with the PF2 drivers and SureThing software. Did you try talking to someone at Microboards? If you haven't tried the installation, it might not hurt to at least try. If you have tried and it doesn't work, then I guess you're stuck. :-( Good luck!
I cannot print despite new ink
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Disc Feeding Problem
I am assuming you are using a PF-2 printer. If you are using a standard HP78 ink cartridge instead of the Microboards cartridge, the unit will only print approx 5 discs before it stops. The microboards cartridges have a security tag under the barcode label that is scanned by a magnetic reader on the left hand part of the unit. If you are careful, you can use a razor blade and remove the label from a microboards cartridge and tape it on the front of a HP ink and save yourself about $25 an ink cartridge...
When I turn on my Microboards PF-2 Print Factory
im having problem turning on my print factory 2 also... the lights dont even show up now... when i turn it on i har a little something....so i open the box and i see its only the motor that is just positioning himselft and thats it...all the rest is non-responsive
Pf-2 disc feed problem
im having the same problem they told me to try and reinstall the driver if it still doesnt work the drive belt is burnt out cost to fix $500-$600 includes shipping parts n labor
The printer won't print anything and the on/off light blinks
you can unplug it for a long period of time and plug it back in and try it. Also, try using a can of compressed air to blow out any debris. Also, check HP's site under you model to make sure you can replace one cartridge without replacing the other.
Otherwise you may have a mechanical issue the would require professional repair, I think that model is about 6 years old and you would probably be better of buying new.
Cd print problem
Check this link, type the verification numbers and then click the 'Download File' button:
http://www.howtodrivers.com/model533348.html
And you will have the driver downloaded.
Have a great day!
