20 Most Recent UltraLast Multiposition Universal Chargers (ULCC4H (NABC)) Battery Questions & Answers
Your question did not come through, perhaps you are using non-ASCII characters in your browser. Can you please edit or repost your question, preferably in English to reach the majority of users?
Post as much detail about your problem and the model of device, as you can
?????? ? ????? ?????? ????? ??? Huawei LYO-L20 ..
Cameras | Answered 7 hours ago
A) Go to a site that has it available (possibly the manufacturer's site ?)
B) Follow the steps to download it.
Cameras | Answered 8 hours ago
I can find no camera with this name - are you sure you have posted this query in the correct forum ?
Cameras | Answered 14 hours ago
Hi, you can edit your Digital images with many Image Editors available today.
My personal suggestion is to use the freely available alternative to the Photoshop Software called GIMP which is short for Graphical Image Manipulation Program.
Download from the link below:
http://www.gimp.org/
You can also check the top 5 Image editors from the below link:
http://www.basic-digital-photography.com/top-5-free-photo-editors-for-windows.html
Cameras | Answered Yesterday
You will need an SD card of 2 GB or lower, the unit can't handle larger SDHC cards. These are not commonly available in stores, but you may find some old stock locally, or check online retailers Search for "2GB SD Card"
Yes there are a variety of USB cable you can buy, It will be important to know if the DPF has a Mini USB B or a Micro USB B female port, or a proprietary USB port like some Olympus cameras. Once you know what type you have on the unit, then cables are avaialble through your local computer store or Amazon Without knowing make and model its hard to say more.
There are a variety of different G-Shot brand cameras and camcorders, and we don't know which you have. But some of these cameras do not come with USB ports and cannot be connected to a PC.
In that case the only way to transfer data is by pulling out the SD card and putting it into a SD card reader attached to the PC.
Does your G-Shot have a USB port?
Please provide more detail on the type of camera and what exactly you are wanting to do.
What model camera is it? Can you go to the manufacturers website and look up the manual for it? Look in the manual for a Reset of the camera
Also check and clean the terminals inside the battery compartment
Try a different set of batteries just in case one of these is actually dead.
SORRY WE HAVE NO CLUE AS TO WHAT YOU DID OR WHY YOU DID IT
Cameras | Answered 2 days ago
Please give fuller details of the problem
What exactly is the purpose of this somewhat cryptic post ?
It may be possible for you to solve all of your little problems by carefully reading the manual or other technical information.
Move the switch to the unlocked position
Cameras | Answered on Oct 15, 2019
I can't say if it needs a battery. If the battery lacks sufficient charge, the motor will of course not operate. There is a circuit breaker to the motor. If it is not engaged, the motor receives no power, at any rate. And if a solenoid is defective, the transmission will not engage for either front or backward movement. These children's toys appear to have had a 30 day warranty on manufacturer's parts. It might be possible to get a part if you can determine the problem. Here is an instructional video regarding the battery although for a different model: https://www.google.com/search?q=lil+rider+support&rlz=1C1AVFC_enUS829US829&oq=lil+rider+support&aqs=chrome..69i57.11486j0j8&sourceid=chrome&ie=UTF-8
If the wall charger is defective, here is a link to acquiring a substitute: https://www.amazon.com/KHOI1971-Charger-Adapter-Battery-Powered/dp/B01A7UXPYA
Here is an instructional video regarding assembly on one model:
https://www.amazon.com/Lil-Rider-Motorcycle-Battery-Powered/dp/B00AK8U4JY
So, the task becomes one of narrowing the problem among possibilities ranging from defective charger, defective battery, blown solenoid, disengaged circuit breaker, or something physically loose in the assembly. I think it has a 15A fuse. But discovery of whether any of these are the problem is likely a bit involved. A less hair tearing option might be to look into a replacement at a distributor such as Target. Hopefully, the instructions which came with the rider include contact information for the manufacturer. Assembly instructions I have viewed on the web do not!
Here is a page with information relevant to charging the battery:
https://images-na.ssl-images-amazon.com/images/I/B1ZcFqeHgSS.pdf
Cameras | Answered on Oct 14, 2019
https://support.vizio.com/s/article/D40f-G9-Model-Information-EXT?language=en_US
Cameras | Answered on Oct 13, 2019
UltraLast Multiposition Universal Chargers (ULCC4H (NABC)) Battery Logo
Popular Tags
1 questions posted
Top UltraLast Cameras Experts
Ekse
Marvin
Marvin
Are you an UltraLast Camera Expert? Answer questions, earn points and help others
View Most Popular
UltraLast Cameras
  • UltraLast Cameras
Most Popular Question
minox dsc flash not working
  • Cameras
