20 Most Recent
Nukote Nu-kote RF196 Black Refill Kit Questions & Answers
Can you tell me how
Hello. Once you have the appropriate refill kit, refilling your Dell black printer cartridge takes only a few steps and a few minutes. First you will create a hole in the top of the printer cartridge for use in the refilling process. To create the hole, place the provided thumb drill at a spot on the top of the cartridge and twist. The tool will drill through the plastic and leave you a pathway into the cartridge. Once the hole has been made, fill the provided syringe with ink by placing the needle into the ink bottle and slowly pulling outward on the plunger. The syringe will fill with ink. Stick the needle into the hole in the top of the cartridge and slowly press the plunger to inject the ink into the cartridge.
Some Dell printer cartridges already have holes for refilling. To check for these holes, pull off the labels on the top of the cartridge. The holes will be clearly visible. Place the tip of the needle into the hole nearest the copper strip of the cartridge and very slowly inject the ink using the syringe. Replacing the top label when you are finished will help prevent any ink spills. The pre-made holes in the tops of newer Dell cartridges may be too small for the needle that comes with a refill kit. If this is the case, use the thumb drill to widen the hole before filling the cartridge.
HP 21 & HP 22
www.inkfilling.net you will find the instructions on videos
Lost instructions
I also have lost the instructions to this refill kit. Where do I drill the hole?
Lexmark X2600 refill problem
many printer manufacturers put something (a chip?) in the circuit of the cartridge to prevent refilled ones from being recognized by the printer....when the "factory" cartridge is empty, the only way for the printer to see a full cartridge again is by using a "new" factory one, ...i guess it's the big name brands way of making sure you buy "their" ink and not use refulls.
Instruction to refill Lexmark 32 Black ink.
VERY IMPORTANT!
Only buy genuine Lexmark printer cartridges. If you go cheap & buy a generic refill, it will leak and gum up your printer. It will destroy your printer.
After getting the new cartridge, you simply pop out the old cartridge and pop in the new one.
Help me
the older lexmark cartriges have a chip that will not let you refill but the newer ones don't have the chip. also if you wait until the cartrige is totally empty it will not work properly
