20 Most Recent
Flip Video Flip Ultra Camcorder Questions & Answers
Hi, I have a 2nd
Welcome to Fixya
Looks like we already have a mainboard issue here. The blinking light should tell you that unit is charging or recording. If you are not doing anything and the light just blinks right away the moment you turn on the unit then the problem is already the board.
Thank you for using Fixya! If you need further help, reach me via phone at
https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
I dropped my Flip video camera on the floor (about
Same here. Wouldn't turn on but when I plugged it into PC for download it did light up saying, "connected." At first the computer did not recognize the device and asked me to re-plug it in. I pulled it out and lo and behold it turned on when I tried the power button. I then plugged it back into the PC and it is currently off loading my videos.
Flip Camcorder Model S1240
Since you have already tried the reset then you are done, nothing else can be done to fix this issue, it is a battery problem The batteries are integrated to the internal circuit CCD board and are not replaceable. If I had the camera I would do my best to take it apart and find out what type of battery it uses and then go to eBay and find the correct cell type and replace it. But unless you are very mechanically minded I would not recommend the trouble.
Flip camera keeps shutting off
check the batteries, if its not that, then make sure it dry on the inside, and if its still causing issues then some of the capacitors in it have gone bad and need to be replaced (cheaper to get a new flip due to surface mounting of components)
