20 Most Recent Radio Shack 15-2104 Remote Control Questions & Answers
I have a va-405 4 in 1 remote and i need the code for a coby dvd player
0260,0269,0258,0255. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier. http://electrohelponline.blogspot.com/ Try this link too http://remotesearch.blogspot.com/
4/13/2018 12:53:09 PM • Radio Shack... • Answered on Apr 13, 2018
Unerversal remote control codes for colby dvd
This remote control has no setup codes for Colby Tv.
5/13/2014 7:34:27 PM • Radio Shack... • Answered on May 13, 2014
Need remote code for vios to coby dvd-937
038,030,031. Try these codes. If you wish to get more, try the following links. Both the sites linked have set-up code list & set-up procedure to many popular brand remote controls. Surf the sites with patience. http://electrohelponline.blogspot.com/ http://electro-medical.blogspot.com/
1/28/2014 4:03:02 PM • Radio Shack... • Answered on Jan 28, 2014
Coby TFDVD7009 codes
9482,0491,0477,0419. Check these codes. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
3/17/2013 5:48:18 PM • Radio Shack... • Answered on Mar 17, 2013
I cannot play a video on my tv using a Colby DVD video remote control
Try by using an other code to setup with it. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and proceedings to some popular model remote control are given
3/5/2013 2:39:57 PM • Radio Shack... • Answered on Mar 05, 2013
I need the code for a rca universal remote to my coby 514 dvd player.
RCA universal remote had no setup codes for Coby.
12/4/2012 4:24:34 AM • Radio Shack... • Answered on Dec 04, 2012
Unerversal remote code for coby dvd
Try these codes.0053 0012 0014 0042
4/22/2012 3:24:31 AM • Radio Shack... • Answered on Apr 22, 2012
2answers
Radio shack 3-in-one remote
Need programming codes for Radio Shack 3-in-one Remote Control for JVC and Sylvania TV
12/5/2011 7:14:35 PM • Radio Shack... • Answered on Dec 05, 2011
4answers
Codes for a coby dvd player
I sucessfully programed the AUX button on my Cable remote to my Coby DVD player (model DVD-227) using code 21107. You can also try these codes: 20778, 21086, 21351.
I hope that helps!
10/17/2011 1:17:18 AM • Radio Shack... • Answered on Oct 17, 2011
The number of white slippers is 3/5 and the number
1/6
3/6/2011 1:42:59 PM • Radio Shack... • Answered on Mar 06, 2011
0answers
I need the codes for
Hi. i have found the two manuals that will give you all the information about the codes and programming procedure. The links are posted below.
15-2104 INSTRUCTION/CODE MANUAL(CLICK HERE)
15-1992 INSTRUCTION/CODE MANUAL(CLICK HERE)
4/4/2009 7:14:46 PM • Radio Shack... • Answered on Apr 04, 2009
The coby problem
Hi flaco_rivers,
Unfortunately, there are no published codes for Coby brand devices, Therefore, I recommend using the CODE SEARCH function. Here's how:
1) Turn on the DVD player
2) Press the DVD key on the remote
3) Hold down P until the red light blinks twice
4) Press 9-9-1 (the red light will then blink twice).
5) Slowly alternate between pressing the DVD key and the POWER key - when the DVD player turns off, that means the remote has found a code that will operate it.
You can read the details about the CODE SEARCH feature in the user manual, which can be viewed at the following web address:
http://support.radioshack.com/support_video/doc66/66339.pdf
I hope this helps - please let me know if I can be of any further assistance.
12/11/2008 7:20:25 PM • Radio Shack... • Answered on Dec 11, 2008
I have a rca universal remote control also a cody dvd player.
Hi freeent316,
Unfortunately, the RCA 15-2104 does not have a code for Cody brand DVD players. The list of codes can be found at the following web address:
http://support.radioshack.com/support_video/doc67/67141.htm
Since there is no published code for Cody brand devices, I recommend using the CODE SEARCH function. Here's how:
5) Slowly alternate between pressing the DVD key and the POWER key - when the device turns off, that means the remote has found a code for the DVD Player and should then operate it.
12/11/2008 6:20:42 PM • Radio Shack... • Answered on Dec 11, 2008
Can I use the Smart Remote 15-2104 for a Cyberhome DVD Recorder?
The product manual doesn't list the Cyber home product. You might want to try a code scan, that might turn up a code set that is close. Here are the instructions:
USING MANUAL CODE SEARCH
If your home entertainment device does not respond
to remote control commands after trying all of the
codes listed for your brand, or if your brand is not list-
ed, try searching for your code.
Follow these steps to search for codes manually.
1. Turn on the desired device.
2. On the 6-In-One Remote, press the appropriate
device key once.
3. Hold down P until the red light blinks twice.
4. Press 9 9 1. The red light blinks twice.
5. Aim the 6-In-One Remote at the desired device
and slowly alternate between pressing POWER
and the appropriate device key. Stop when the
device turns off — a working code has been
found.
Note: In the search mode, the remote sends IR
codes from its extensive library to the selected
device, starting with the most popular codes.
Because of the library’s size, this procedure may
take some time. When the red light blinks three
times, the search of every code is complete.
6. Press P once to lock in the code.
3/20/2008 7:47:31 PM • Radio Shack... • Answered on Mar 20, 2008
Trying to program element TV with radio shack 5&1 remote
https://www.manualslib.com/manual/694349/Radio-Shack-Remote-Control.html
11/2/2022 8:51:43 PM • Radio Shack... • Answered on Nov 02, 2022
2answers
Radio shack do you have Homework converter box remote control
Sorry this is not Radio Shack.
10/20/2022 6:50:52 PM • Radio Shack... • Answered on Oct 20, 2022
I need a manual for a radio shack cat. no 63-1009a thermometer
notify radio shack
12/7/2021 1:21:35 PM • Radio Shack... • Answered on Dec 07, 2021
Program radio shack 4 in one remote for mishibushi ws65311 projection tv
read your instructions --or radio shack site for them
5/4/2020 12:34:05 PM • Radio Shack... • Answered on May 04, 2020
Televison & Video Logo
Popular Tags
28 questions posted
Top Radio Shack Televison & Video Experts
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Radio Shack Televison & Video
Most Popular Question
coby tfdvd7009 codes
  • Televison & Video
