20 Most Recent
Proton VT-218 20" TV Questions & Answers
Proton tv model LT32C1P1 won't come on
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Black rectangular box shows on screen
This is simple: set in the closed caption menu (some cable boxes also have it) called TEXT. Look in the menu and turn it off first in the set and also in the box used if used for signal.Odd feature and never really took off--designed so some channels like PBS etc could broadcast text.
My Proton TV loses it's
Please let me know the model no. of your unit. Also, does the symptoms is the same to all inputs?
Jdvillanueva
I have a problem with
I am Sorry to Hear regarding the Problem. Unplug the Unit for Few Minutes, say 15 Minutes and then Turn it ON. Do you still see the Problem?
Have you tried to Run DVD Player. If not Use it and Check, if that is still the Case?
If Yes, this is an Internal Failure and You need to Open the TV to get it Resolved.If you wish, you could Contact a Local TV Repairman to get it Resolved or let me know the Make and Model and i would be able to Guide you.
Make sure to take all the Precautions and all the Security Measures.Also, tell me How Old the Unit is?
Make sure that you need to have Tools like Multimeter and Magnifying Glass and you need to have the Schematics ( We could also Search for Cost effective Service Manual, if that is available with any Vendor ).
Let me know,so that we could Proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
