20 Most Recent Proton NT-3460 32" TV Questions & Answers
I need to know the serial number of my flyback
Hi, my name is John. Welcome to FixYa. Look on the flyback. Thanks for choosing FixYa.....John
3/5/2016 6:14:35 AM • Proton NT-3460... • Answered on Mar 05, 2016
Hdm1 cable hook up wher is it
If you can't find it, it probably doesn't have one.
10/14/2014 2:46:34 PM • Proton NT-3460... • Answered on Oct 14, 2014
2answers
I have an 8-9 year
Hi:
when using DVi input you will still need two audio cables for the DVI output to get audio, DVI does not carry audio as with Hdmi cables if you are using a DVI to HDMI adapter then you will still have to use the DVI Audio Output jacks for audio.
2/24/2011 7:48:19 PM • Proton NT-3460... • Answered on Feb 24, 2011
My proton hdtv is only 3 1/2 years old and it just
This sounds like it could very well be a failed capacitor. I would take the back off the tv and inspect the capacitors on the boards and see if any are bulged or leaking. Most likely being that its a 32" you may want to consider replacing it as it would be a wiser investment over repair. If you need further assistance please let me know.
thank you,
Lee
1/21/2011 9:49:38 AM • Proton NT-3460... • Answered on Jan 21, 2011
My proton NT3460 32"t.v erase the serial number of
Hi, my name is John. Welcome to FixYa. The flyback should have a number on it. Thanks for choosing FixYa...John
12/7/2010 2:07:09 PM • Proton NT-3460... • Answered on Dec 07, 2010
My proton t.v turn off and i need to replace the
Hello
I've tried a few minutes ago to get the serial number of your TVs LOT, before I present a solution before you. I've went through all sites, that I know, where I can get the LOT serial number, but went in vein.
Replacing the LOY with an other type, and number will surely spoil your TVs most of the components.
You just do one thing. Goto an electronic spare part shop, with the LOT in your hand, and inform them about the details of your TV. They can help you. By checking its winding continuity, they can select the right one for you. Winding continuity is important and should ckec properly. You can't check the winding continuity of the EHT winding, and it is ussualy shorts, and that short causes the LOT get damaged. The base connection windings won't short at all, and you can check its by measuring its resistance with a multimeter, and choose a suitable and exact replacement.
Never put any unknown LOT. Ok.
11/30/2010 9:25:55 AM • Proton NT-3460... • Answered on Nov 30, 2010
2answers
Ac-adapter for 32" proton LCD
Click here to see a few power adapters for your TV.
8/26/2009 3:32:22 AM • Proton NT-3460... • Answered on Aug 26, 2009
Where do i plug dvd vcr player into tv there r 3 sets of red yellow&white
Select an input set on the back (example "Video 2"), use the RCA cables to connect the video component player to the selected input. yellow is video signal, red & white are the audio. To view/listen, select with the remote using the button called "TV/Video" or something similar. Hit the button repeatedly until you are viewing the desired source.
2/19/2009 4:37:12 AM • Proton NT-3460... • Answered on Feb 19, 2009
4answers
Protron PL TV-3250 32" LCD
sounds to me a power ICB has gone bad if you can get it replaced under warranty that is your best bet. If not then you can call the manufacturer and have them fixes still at your expense. I would call them in advance and get a price for it all general estimation. Make sure its what you want to do.
hope this helps answer your problems
Nate 08:38:28cst
6/16/2008 1:51:56 AM • Proton NT-3460... • Answered on Jun 16, 2008
Black screen with audio available
Only thing I can tell you here is contact proton. This is a hard company to get any customer service from after you buy a product . I also may suggest go back to where you bought the set, maybe they have a servicer who can get you an owners m,anual and give you the info your looking for. Good Luck Taiwan Headquarters US Distributor Address: PROTON USA 15364 E. Valley Blvd City Of Industry CA 91746 U.S.A No.77, Sec.1, San -Ming Road Panchiao, Taipei-Hsien, Taiwan, ROC Email: [email protected] [email protected] Telephone: +886-2-2962-5135 PH 626-855-2129 Fax: +886-2-2964-8664 FX 626-855-2147
8/9/2006 6:47:35 AM • Proton NT-3460... • Answered on Aug 09, 2006
Can I program a Roku remote to my 42 inch proton TV
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name of your device in its search box at the right column of the display window. It will help you to find the details easily. https://homenol.blogspot.com/ https://elektrotricks.blogspot.com/ https://remotesearch.blogspot.com/ https://electrohelponline.blogspot.com/
7/11/2021 1:42:32 PM • Proton Televison... • Answered on Jul 11, 2021
0answers
How do you repair a proton 320 clock radio
What is wrong with it.
8/2/2018 11:32:08 PM • Proton Televison... • Answered on Aug 02, 2018
I have a 37 inch proton tv that I can’t keep power on. What could be the problem?
What exactly happens when the set shuts off?...does the power indicator lamp stay on, or does it blink. Also do you still have sound?
5/1/2018 11:27:34 PM • Proton Televison... • Answered on May 01, 2018
The screen is green when I turned on my Proton 4250 42 In. LCD Television
The TCON board or the LCD panel is faulty. You have to change the tcon board to confirm the fault If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
11/24/2016 7:19:48 PM • Proton Televison... • Answered on Nov 24, 2016
Does a proton tv flatscreen backlight have a replacement fuse
No. There no seperate fuse for backlighting.
7/6/2016 3:45:05 PM • Proton Televison... • Answered on Jul 06, 2016
Does a proton flat screen TV. ..backlight have a replacement fuse
Normally all the backlight inverters have fuse. It would be an SMd type. Of you wish to get some more details check the link below http://electro-medical.blogspot.com/
7/6/2016 7:17:10 AM • Proton Televison... • Answered on Jul 06, 2016
Do proton tv backlights have a replacement fuse.
Back-light inverter board will have a fuse. Refer its circuit diagram to locate it. If it should blow up, there will be sufficient reason. Some short circuited components/s. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Circuit diagrams of many popular brand TVs and other devices are given.
7/6/2016 3:38:28 AM • Proton Televison... • Answered on Jul 06, 2016
Proton NT-3460 32" TV Logo
Popular Tags
11 questions posted
Top Proton Televison & Video Experts
matt martin
matt martin
Bob Kirkwood
Larry
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Proton Televison & Video
Most Popular Question
ac adapter 32 proton lcd
  • Televison & Video
