20 Most Recent
Proton NT-3420 32" TV Questions & Answers
Where to buy a replacement power cord for a proton
Hello there,
This is a link to buy a new power cord make sure both ends are the same
http://www.pronto.com/user/search.do?displayQuery=t.v.%20replacement%20power%20cord&SEM=true&query=t.v.%20replacement%20power%20cord&adid=1192058243-4978671-0_gs&ref=t.v.%20replacement%20power%20cord&creativeid=3182728172&site=
Proton tv model LT32C1P1 won't come on
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Black rectangular box shows on screen
This is simple: set in the closed caption menu (some cable boxes also have it) called TEXT. Look in the menu and turn it off first in the set and also in the box used if used for signal.Odd feature and never really took off--designed so some channels like PBS etc could broadcast text.
My Proton TV loses it's
Please let me know the model no. of your unit. Also, does the symptoms is the same to all inputs?
Jdvillanueva
