20 Most Recent Proton MM3201VT 32" TV Questions & Answers
What is wrong with it.
Proton Televison... | Answered on Aug 02, 2018
The TCON board or the LCD panel is faulty. You have to change the tcon board to confirm the fault
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Proton Televison... | Answered on Nov 24, 2016
No. There no seperate fuse for backlighting.
Proton Televison... | Answered on Jul 06, 2016
Normally all the backlight inverters have fuse. It would be an SMd type.
Of you wish to get some more details check the link below
Back-light inverter board will have a fuse. Refer its circuit diagram to locate it. If it should blow up, there will be sufficient reason. Some short circuited components/s. If you wish to get some details; check the site linked here. Pull up older posts.
Circuit diagrams of many popular brand TVs and other devices are given.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Proton Televison... | Answered on Oct 14, 2015
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the relative post easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Proton Televison... | Answered on Apr 28, 2015
This is simple: set in the closed caption menu (some cable boxes also have it) called TEXT. Look in the menu and turn it off first in the set and also in the box used if used for signal.
Odd feature and never really took off--designed so some channels like PBS etc could broadcast text.
Proton Televison... | Answered on Apr 03, 2012
Please let me know the model no. of your unit. Also, does the symptoms is the same to all inputs?
Jdvillanueva
Proton Televison... | Answered on Sep 14, 2011
I am Sorry to Hear regarding the Problem. Unplug the Unit for Few Minutes, say 15 Minutes and then Turn it ON. Do you still see the Problem?
Have you tried to Run DVD Player. If not Use it and Check, if that is still the Case?
If Yes, this is an Internal Failure and You need to Open the TV to get it Resolved.If you wish, you could Contact a Local TV Repairman to get it Resolved or let me know the Make and Model and i would be able to Guide you.
Make sure to take all the Precautions and all the Security Measures.Also, tell me How Old the Unit is?
Make sure that you need to have Tools like Multimeter and Magnifying Glass and you need to have the Schematics ( We could also Search for Cost effective Service Manual, if that is available with any Vendor ).
Let me know,so that we could Proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Proton Televison... | Answered on Apr 06, 2010
Hi
There is no Point in getting the Remote repaired as the cost of Repair would be much more than the new remote. Yes, Original Remote is not available.The substitute remote is :-
http://remotes.com/store/protron/pltv3250.html
Is that the same one you purchased? Have you programed it correctly?
It could be an issue with the TV. The IR sensor which senses the signal from the remote might be Defective.
Let me know, if needed further assistance.
Hope i helped you.
Proton Televison... | Answered on Jan 24, 2010
Televison & Video Logo
1 questions posted
Top Proton Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Proton Televison & Video
Most Popular Question
volume tv goes only when tv gets hot
  • Televison & Video
