20 Most Recent Pioneer DEH2200UB with iPod Direct Control and USB Input Car CD MP3 Player Questions & Answers
2answers
How do you switch the illumination color from Red
Actually you can change the color. Turn the Unit off. Press and Hold MC. The menu will pop up, turn to Ilumi turn it to desired color. It only comes in Red or Green.
9/7/2022 4:01:53 PM • Pioneer... • Answered on Sep 07, 2022
My Pioneer DEH-2200UB car receiver was functioning
The unit is defective, have it repaired by the maker.
7/7/2017 5:34:23 PM • Pioneer... • Answered on Jul 07, 2017
Front speakers turned off
find how to operate the fade button and reset to equal front and back
5/3/2013 7:11:06 AM • Pioneer... • Answered on May 03, 2013
I installed a pioneer DEH-2200UB. i used google to
if you have a power wire that is coming from your car harness... you should check it that it has power.. and then plug it back in. or leave it plugged in anyways. and then you need to check your ground wire that it is grounded corrrectly. Next you need to check aux and other wires... if you have an amp or subs you need to check the fuse and wires also...
Most likely you either blew a fuse or a wire came disconnected is all. :)
Best Reguards, Premium FixYa Support
7/27/2011 1:10:47 AM • Pioneer... • Answered on Jul 27, 2011
I WOULD LIKE TO DOWNLOAD A pioneer super III
You can download and print the instruction manual in PDF format by clicking this link.
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
3/11/2011 10:01:57 AM • Pioneer... • Answered on Mar 11, 2011
I installed my pioneer deh-2200ub
Turn the stereo off with the button in the top left corner. Hold the button down until the stereo is turned off.
Then push the function button on the remote control and you will see clock settings.
3/8/2011 2:55:24 AM • Pioneer... • Answered on Mar 08, 2011
I have a deh-2200ub model... everything is hooked
What kind of vehicle? If it's on a Ford, make sure you connect the blue/white power amp wire (Ford installs factory amps in their vehicles)
12/9/2010 12:50:49 AM • Pioneer... • Answered on Dec 09, 2010
How do you install a
You will need these parts from Metra Electronics :
99-3200 Dash kit.
In the instructions that come with this, it tells how to R&R the dash.
https://metradealer.com/files/products/INST99-3200.pdf
Either a 40-GM10 or 40-GM12 Antenna Adapter
and a 70-1858 Wire Harness. This wire harness plugs into your factory harness and then you can use **** connectors to match up the other side to the radio. Red to Red, Yellow to Yellow...etc on down the line. Radio mounts into dash kit and screws into dash.
11/26/2010 9:16:54 PM • Pioneer... • Answered on Nov 26, 2010
How do i set the clock? I have tried many ways
Welcome to FixYa!
Here is how to set the clock.
Initial Settings
1 Press SRC/OFF and hold until the unit
turns off.
2 Press M.C. and hold until CLOCK SET appears
in the display.
3 Turn M.C. to select the initial setting.
After selecting, perform the following procedures
to set the initial setting.
CLOCK SET (setting the clock)
1 Press M.C. to display the setting mode.
2 Press M.C. to select the segment of the clock display
you wish to set.
Hour-Minute
As you select segments of the clock display, the
selected segment flashes.
3 Turn M.C. to adjust the clock.
If you need the manual you can get it in the link below. page 11
http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/DEH-2200UB_OwnersManual0922.pdf
Good Luck
11/9/2010 11:17:34 PM • Pioneer... • Answered on Nov 09, 2010
Can not tune in a radio station
I hope your car antena is perfactly ok, for tuning in the stations. Also it might need servicing the main board and tuner area. Resoldering the whole unit and also check out for Signal diodes in case it has been shorted. Diodes are in small size, mostly coloured red and have symbols of blocked arrowhead on the board. If cannot do it yourself, try to get a qualified technican. Thanks
5/15/2010 7:56:19 AM • Pioneer... • Answered on May 15, 2010
Help wiring Pioneer Ca9pa V6 650 from Mazda Atenza
When the unit was in the Mazda, it was run and monitored by the Body Control Module computer. Moving dedicated units from one vehicle to another seldom works the way you expect. https://www.google.com/search?q=pioneer+ca9pa+v6+650+wiring+diagram ..
2/25/2024 10:29:32 PM • Pioneer Car... • Answered on Feb 25, 2024
2answers
4500 pioneer equalizer how to find the four wires
Four wires ... which four wires.
2/4/2024 8:29:07 AM • Pioneer Car... • Answered on Feb 04, 2024
Can I connect my smartphone to the Pioneer AVH-500EX?
See page 37 of manual. Procedure is given there. AVH-601EX_600EX_501EX_500EX_OpManual062918.pdf (pioneerelectronics.com)
1/7/2024 9:56:38 AM • Pioneer Car... • Answered on Jan 07, 2024
Pioneer DEH2200UB with iPod Direct Control and USB Input Car CD MP3 Player Logo
Popular Tags
23 questions posted
Top Pioneer Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Car Audio & Video
Most Popular Question
front speakers turned off
  • Car Audio & Video
