20 Most Recent
BOSS AUDIO SYSTEMS AVA1204 7Band Car Equalizer Questions & Answers
How to wire it to make the bass cuts off when
This unit has a separate EQ band for the subwoofer-- you'd connect the sub-out from your CD player to the sub input on the EQ, and the sub-out from the EQ into the input on the sub amp.
The "sub" slider would then adjust the sub volume.
If your CD player doesn't have a sub-out, and you are just using one of the regular front/rear outputs to feed the sub amp, then the sub volume will follow the other sliders toward the left side of the unit, which is less desirable.
Screen will not turn on it came on then it stop
Try resetting the system. Follow these instructions:
- Push the RES or RESET button with a pen or similar object.
- The button location depends on your Boss model.
- Turn the power on.
Download the correct manual for your model in order to locate the RESET button:
Boss Car Audio Manuals
Find your Boss manuals using the link above.
How to reset screen
Not sure which model you have, but on most Boss models there is a little button on the front of the unit that you need to push with a pen. The button may say RES next to it. It also may be in the back of the unit.
Somewhere on the unit there is a button! Push it!
Find your manual using the link below if you can't find the button.
