20 Most Recent
Optoma MovieTime Digital DVD Multimedia Projector Questions & Answers
Connect projector to laptop
I'm sure this answer will be very much after your presentation, but if its a MS Windows laptop with an active Internet connection you can try and connect the projector and MS Windows will attempt to look for the driver automatically.
Projector still works but started making a load
This is a DLP projector. In it the image is generated this way: a bulb makes the light (a fan cools it); the light is projected on a circuit with a million tiny mirrors on it - each can be tilted individually so tilting them one at a time a black/white image is generated; this image is passed thru a wheel tha has colored screens on it that turn - the color is put on the image; that final image is projected on the screen.
You hear a roaring sound because a rotating part is failing. If you're lucky it's the fan and replacing it will cost you $5 plus the labor - simple but if you have never done this before don't try it, it's fiddly, leave it to a pro. If your unlucky it's the wheel and in that case it's going to be very expensive - only the wheel itself will cost you at least $200. Including the very complicated job of completely dismantling the projector, replacing the wheel, putting it all back together and realigning all of them optically it will cost you more than $500. Ask a quote before accepting the repair, you might find out that it will be cheaper just to get another one.
How do I do a hard reset on a optoma uhd55 projector.
To perform a hard reset on an Optoma UHD55 projector, you will need to locate the reset button on the projector. This button is typically located on the back of the projector, near the power cord. Press and hold the reset button for at least 10 seconds, or until you see the projector's LED light begin to blink. Release the button and the projector will reset to its default settings.
My projector has a password locked but I forgot the password. If there is any way to turn it on, please help.
Optoma DLP projector
EX631
Reset instructions according to this
https://factory-reset.com/wiki/Optoma_Service_Menu
Optoma Service Menu Instructions
Most of our Optoma Service Menu methods require the use of an original remote, typically you can not do it with just the buttons on the front of the set. If you no longer have your remote or have damaged it, we recommend that you purchase a
Optoma Remote before trying to enter the service menu.
Method 1
- Press simultaneously {UP} & {ENTER} buttons twice.
- Press simultaneously {LEFT} & {ENTER} buttons twice.
- A Service Menu will be displayed
- Then to access the Full Service Menu: Press the {UP}, {LEFT} & {DOWN} buttons once.
- To exit, turn the Projector Off.
Method 2
- Press the {UP} {UP} {LEFT} {LEFT} buttons.
Method 3
- Press the {POWER} {LEFT} {LEFT} {MENU} buttons.
Method 4
- Press simultaneously the {RE-SYNC} {ENTER} {SOURCE} buttons on the Projector.
Method 5
- Press the {POWER} button.
- It will show: "Power Off" or "Picture Mute".
- Then press the {LEFT} button 8 times slowly.
Method 6
- Press {MENU} {6} {1} {9} {MENU} buttons.
- To exit the Service Menu: Press {MENU} {6} {1} {9}
