20 Most Recent
Asrock P4S61 Motherboard Questions & Answers
Asrock p4s61, tried 1gb pc3200 to max memory to 3gb, won't boot.
you quote one of your memory sticks as being pc 2700 when earlier in your text you qoute pc3200.
Firstly pc 3200 is 400 mhz clock speed memory.Secondly, pc 2700 is 333mhz clock speed and you acnnot mix the two on the same board. Thirdly does your board support 3ghz anyway. If you are running a board at 400mhz, pc2700 memory will not run at 400mhz.
Solution, take out the pc 2700 memory and all will be well.
I have an E-box computer
The updates weren't the cause of the failure, they were just the straw that broke the camel's back: one of the power regulators on the board was failing from a long time ago (age related, nothing you or anyone has done) and the effort required by the intense activity or installing the updates has caused it to fail for good.
I'm afraid that there is nothing left to do - hardware failure. Sorry, time for a new motherboard.
Show me in diagram where
hi kamzaimi, just check out the tutorial i have give below so that its so easy to understand this process to connect USP port to your motherboard
CLICK HERE to view the tutorial
Good luck ! if you think your problem solved don't forget to rate
Dont show nothing on the screen when you turn on
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Hi, i have a asrock P4s61 mother board, please
Hi
Before going any further, I would like to confirm if the device appears in Device Manager. Click Start button, type DEVMGMT.MSC and press Enter.
Please check if the USB device is listed in USB category. If so, is any error listed?
To troubleshoot this issue, you can try the following steps:
Rename in Windows Recovery Environment:
1. Keep pressing F8 upon restarting and choose Repair your computer in the boot menu.
2. In the System Recovery Options dialog box, click Command Prompt.
3. In Command Prompt, type in the following and press ENTER at each command:
CD c:\windows\inf
ren oem*.inf *.old
CD C:\Windows\System32\DriverStore
ren infcache.1 *.old
4. Close the Command Prompt window, and then click Restart.
Please connect the USB device again.
Let us know if you want to know something else accept the suggestion.
Thanks for contacting fixya.com
My asrock have problem to bring blue sicreen I
I will assume youre running XP? I have fixed this a lot by formatting and reinstalling windows and works most of time. Can also be caused by faulty memory. If you have more that 1 stick of memory try just using 1 stick at a time and see if this works.
I'm having difficulties with my AGP Card
If your motherboard shorts out and fries anything, replace it immediately. It is simply more cost effective to replace it than try to troubleshoot the card unless it has an obvious problem like bad capacitors.
No image
check you ddr ram, make sure to get a good set of module. remove the cmos battery temporarily. plug in the monitor to the onboard VGA. test again
